Car pulling right under power
Old Nov 18, 2005 | 01:43 PM
Hvymtlc5's Avatar
Hvymtlc5
Default Car pulling right under power
Seems like my 01 pull / torques very hard to the right in the first few gears (M6) when under max power shifts. I thought it was me at first unconsciously turning the wheel, but it's not.............feels like something is shifting or loose in the rear. I've looked, but haven't found anything out of the ordinary. Ideas?
Old Nov 18, 2005 | 01:56 PM
huttler's Avatar
huttler
Sounds like a front wheel drive vehicle!!
Old Nov 18, 2005 | 02:02 PM
jimcork1's Avatar
jimcork1
My 64 would pull when tire pressure was off by more than 2#s. Also consider the tires must be matched set for posi. rearend. Check front tires also for pressure. 99 Nassau Blue
Old Nov 18, 2005 | 02:06 PM
Hvymtlc5's Avatar
Hvymtlc5
Tires match and are at 28 PSI.
Traction control turned off.
Old Nov 18, 2005 | 04:41 PM
huttler's Avatar
huttler
does it do it everytime? Could be the pavement you're on because as the road ages low points develop because of where vechles tires most offen contact the road. This causes vehicles with wider tires and stiff sidewalls to get pulled around since the tire cannot maintain 100% even contact on the road. Lets say your left tires have full contact but your right have only 70%. Your vehicle will tend to pull.
Old Nov 18, 2005 | 08:07 PM
HZO61's Avatar
HZO61
Have the alignment checked at a good shop, perferrably a shop that does lots of vettes. The rear toe is probably out causing the "torque steer" you're feeling under acceleration.
Old Nov 18, 2005 | 08:27 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
the OEM tires are to be at 30 lbs. not 28 lbs.
Old Nov 18, 2005 | 08:42 PM
vette747's Avatar
vette747
In addition to what was said, mine started to pull right when I was on the gas and on the left when I was releasing the pedal. Just a little thought. That was the rear tie-rods. The driver side was looser than the passenger side. This is easy to check. Jack the car and try to move the wheel from left to right. If it also moves from top to bottom, then that could be the wheel bearing. My C4 had the same problem. I found it strange since the front tie-rods were ok. I think it was due to track time. That could also be a A arm busing. Are tires wear evenly.
Old Nov 22, 2005 | 01:31 PM
Hvymtlc5's Avatar
Hvymtlc5
Good suggestions. Tire wear is even....just feels like something is loose or the way it feels with traction control on when you try and do some hot rodding and all sorts of automatic compensation is going on back there.
Old Nov 22, 2005 | 01:39 PM
BobbyG's Avatar
BobbyG
As the engines rpm's increase so does the torque. When you dump the clutch the drive-train locks up and twists the chassis. This can cause an unequal weight distribution allowing one tire to hook up better than the other, actually steering the car from the rear.
Just my thoughts.
Bob
To Car pulling right under power
