Best differential oil to use?
Old Nov 18, 2005 | 08:49 PM
David426's Avatar
David426
Default Best differential oil to use?
Should I use GM's brand plus an additive or is there a better alternative to use without having to use an additive. I've read that if you use the GM brand you have to use an additive. WTF?.. I have not had any problems with my differential so far. I'm scared it will leak if I start jacking with it. Yeah I know It has to be done though. Has anyone tried a sealer with a diff oil change? Is there such a product?
Old Nov 18, 2005 | 08:51 PM
Mudlizard's Avatar
Mudlizard
Get ya some Royal Purple Synthetic Diff lube and thats all you need. No additives required w/RP.
Old Nov 18, 2005 | 09:00 PM
Tex_Vette's Avatar
Tex_Vette
Just Passin' Thru
I don't have the knowledge or experience to recommend one brand of fluid over another. However, Red Line makes (at least) two types of gear oil that are supposedly suitable for the C5. Their 75W90 already contains the limited-slip additive in the "correct" proportion for the C5. You can also get their 75W90NS and their limited slip additive and mix your own. I chose the 75W90 route so I didn't have to try getting the ratio right. Just changed tranny and diff fluids for the first time last weekend, so I don't have enough miles on the change yet to comment on better or worse. I don't think any of the premium synthetics will cause your diff to start leaking, if it wasn't already. And, I don't know of one that has a sealer included. Seems like that might gum up the works, if you get my drift.
Old Nov 18, 2005 | 09:06 PM
SGT. PYLE's Avatar
SGT. PYLE
Get the Redline 75W90.
Old Nov 18, 2005 | 09:12 PM
rc51racer's Avatar
rc51racer
I just changed the Diff. oil last weekend. I went with Mobil 1 synth. 75w-90 and limited slip add. Going to check the 6 speed tomorrow. After I go out for a Saturday morning tire burn of course. We are all clear here. Zip tied and loving it!
Old Nov 18, 2005 | 09:22 PM
Mudlizard's Avatar
Mudlizard
As you can see, people are brand specific. We all have what we think works the best and stay loyal to that brand.
You wont go wrong using an oil that needs an additive or one that doesnt. Just make sure you know what "your" choice of oil is going to need.
Good luck
Old Nov 18, 2005 | 09:40 PM
rws.1's Avatar
rws.1
When it comes to oil for my car... I only use Brands that I trust. the bigger the company, the deeper the pockets... the happier I am.
So its Mobil/Exxon (one organization)
or Shell/QuakerState/Pennzoil (one organization)
for me....
Old Nov 18, 2005 | 09:45 PM
rc51racer's Avatar
rc51racer
Clear!
Old Nov 18, 2005 | 09:47 PM
MNCrystalRed2011's Avatar
MNCrystalRed2011
That's what I use.
Old Nov 19, 2005 | 01:01 PM
DPG's Avatar
DPG
St. Jude Donor '06
Mobil 1 Syn good enough as motor oil, Mobil 1 Syn is good enough for my trans and diff fluids.
Old Nov 19, 2005 | 01:30 PM
W Muller's Avatar
W Muller
Default diff lube
Make sure your car is level when you fill. Leave it down about 1/8" or so from the fill hole. If you overfill it will come out the vent and make a mess.
Old Nov 19, 2005 | 02:22 PM
Midwest Vette's Avatar
Midwest Vette
I used amsoil severe gear. So far so good.
Old Nov 19, 2005 | 03:16 PM
red97vette's Avatar
red97vette
I just put in Royal Purple on Thursday night (thanks for the help Chris!!!) and ive had no problems at all. Im happy with it. I had about 61k on the clock before I changed it out. The fluid in there from before (factory) was still doing very good...didnt need to change it afterall..o well, doesnt hurt..
dan
Old Nov 19, 2005 | 07:58 PM
edensknight's Avatar
edensknight
Old Nov 19, 2005 | 08:35 PM
C5Jim's Avatar
C5Jim
Originally Posted by edensknight
Red Line = Excellent oil.
I've got it in the vette and in my '88 IROC with 368,000 miles and the posi rear still works!!
Old Nov 19, 2005 | 09:01 PM
The Yav's Avatar
The Yav
Gentleman,
Can you get RED LINE diff oil at major discount auto parts stores? If so please provide names of the stores. In addition how much oil is required.
v/r
THEYAV
Old Nov 19, 2005 | 11:05 PM
SGT. PYLE's Avatar
SGT. PYLE
I have ordered all of mine from WestCoastCorvette.com I have looked at AutoZone, Advanced and Napa with no luck. You will need 2 qts.
To Best differential oil to use?
Old Nov 20, 2005 | 10:21 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
get redline! they are the best
Old Nov 20, 2005 | 11:07 AM
ErnieN85's Avatar
ErnieN85
Old Nov 20, 2005 | 09:52 PM
coast7's Avatar
coast7
Good luck
Well said for just about any answer posted here to a question that begins, "What is the best....?
