Thoughts on output shafts
Old Nov 19, 2005 | 06:39 PM
James1098's Avatar
James1098
Default Thoughts on output shafts
I am in the process of changing a bunch of things on my Z. It will be making quiet a bit more power (PTK turbo, heads, cam) and I am considering upgrading the output shafts.
The car will get raced at the track mostly on dr's. I may eventually put some slicks on it.
Should I upgrade the shafts or change anything else for track use? Where is the best place to purchase them?
Old Nov 19, 2005 | 06:41 PM
LoneStarFRC's Avatar
LoneStarFRC
Especially if you are going to be seeing some hard launches and using slicks. Give DTE a call. They can fix you up with the best. HTH
BTW, I would also recommend DTE's transaxle brace so you won't be destroying your diff.
Old Nov 19, 2005 | 08:33 PM
James1098's Avatar
James1098
I have the brace.
If I change the shafte, should I do both or just one?
Old Nov 19, 2005 | 09:01 PM
LoneStarFRC
Originally Posted by James1098
I have the brace.
It's really not that much more to get the right side shaft too. Might as well have both and have the piece of mind knowing that you then have pretty much of a bullet-proof diff.
Also check out LG's aluminum driveshaft couplers too. They will strengthen that area too.
Old Nov 20, 2005 | 01:31 AM
cheemsaf's Avatar
cheemsaf
For peace of mind...do both
Old Nov 20, 2005 | 12:58 PM
usnskeet21's Avatar
usnskeet21
Default Dte!
Give DTE a call. I just put both in my 99. Couldnt ask for better service or a better looking product. Went to the track for the second time with the car with alot better results !! IT DROVE HOME !!
Old Nov 20, 2005 | 09:32 PM
James1098's Avatar
James1098
Is there much difference in what Lingenfelter and what DTE sells?
Old Nov 22, 2005 | 07:56 PM
LoneStarFRC
They may be offering the DTE products in some of their packages. Good choice, since DTE make very good parts.
To Thoughts on output shafts
