Which side is P0430?
Old Nov 20, 2005 | 03:49 AM
larrysb's Avatar
larrysb
Default Which side is P0430?
I'm getting a P0430 every once in a great while. Low efficiency catylist, bank 2.
Which side is kicking the code? Engine runs strong, no sign of malfunction. I have a Z06 (2 high-efficiency cats) H-pipe installed in place of the 4 cat H-pipe that came on my 02 vert. It's kicked it once in a great while. Not sure if there's a problem that I can fix or not. Might swap the rear O2 on that side to see what happens.
Old Nov 20, 2005 | 08:20 AM
C5COM67's Avatar
C5COM67
I was getting that code and the P0420 (same thing on bank 1) All that code is telling you is that a comparison of front and rear O2 sensors is indicating a possible ineffeciency with the cats. O2 sensors are fine. I got it after installing Dynatech with HIflow cats, but only after about 30 min of driving. I plan to get the rear O2s edited out when I get tuned (after the new cam).
Hope this helped
Old Nov 20, 2005 | 12:22 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Bank 2 = passenger side
To Which side is P0430?
