Clutch Replacement Question
Old Nov 21, 2005 | 02:19 AM
Cscokd's Avatar
Cscokd
Default Clutch Replacement Question
When you guys replace your clutch and flywheel, did you also replace the bolts for flywheel to crankshaft and pressure plate to flywheel? I noticed Thunder Racing offers ARP bolts but they are very expensive. What's the concensus here? Is this necessary?
John
http://www.thunderracing.com/catalog...&vid=7&pcid=18
Old Nov 21, 2005 | 01:34 PM
Cscokd's Avatar
Cscokd
Nobody has any comments?
Old Nov 21, 2005 | 04:48 PM
RobertEarl's Avatar
RobertEarl
I have never heard of the stock bolts ever failing.
Old Nov 21, 2005 | 06:37 PM
turboc5's Avatar
turboc5
If I remember correctly, I think my texstraila clutch came with new bolts. Never heard of them braking BUT it is cheap insurance.
Old Nov 21, 2005 | 06:43 PM
vettenuts's Avatar
vettenuts
Haven't had to do the clutch yet, but I might go for the ARP's simply because they are stronger and getting to the clutch is a royal pain. I replaced all my internal bolts with ARP's when I did the cam, but that is just me I guess.
Old Nov 21, 2005 | 08:48 PM
jmzvet's Avatar
jmzvet
Did a clutch R&R recently and used new factory bolts.
Old Nov 22, 2005 | 12:20 AM
unstressed's Avatar
unstressed
Flywheel to crank bolts come with a threadlocker on them, pressure plate bolts are not coated.
I would replace flywheel to crank bolts, but not bother with pressure plate bolts if I did it again.
To Clutch Replacement Question
