Convt. Top
Old Nov 21, 2005 | 12:23 PM
JCsSilverVette's Avatar
JCsSilverVette
Default Convt. Top
My back window just popped right off the glue/adhesive just gave out due to me always putting up and down ALL THE TIME. Just needs to be cleaned then glue again, in my opinion. I went to an auto shop and said they couldn't fix it, went to an upholstery shop=can't fix it went to Chevy dealer=can't fix it, called a top shop=can't fix it. Anyone live in or around Torrance, CA know of any place I can go? Help or suggestions from others would be appreciated.
Thanks,
Jared C.
http://i19.photobucket.com/albums/b1...e/DSC00104.jpg
http://i19.photobucket.com/albums/b1...e/DSC00105.jpg
http://i19.photobucket.com/albums/b1...e/DSC00103.jpg
Old Nov 21, 2005 | 12:31 PM
JD's C5's Avatar
JD's C5
Don't know what year yours is but my 2000 did the same thing. It really was just more from drying out and sun i.e. normal wear. I had to replace the convertible top. I got a great deal from a forum member and took it to a trim shop who put the new one on. Every place I took it said the same thing that it wasn't repairable.
I guess you could just try gluing it again but think new top is your best bet. Good luck.
Old Nov 21, 2005 | 01:59 PM
white top's Avatar
white top
I have seen a couple posts re. same problem. Guys said they fixed themselves by using silicone sealer as I recall. Tough part is figuring a way to clamp/keep pressure on til it sets up. what year is your car.
Old Nov 21, 2005 | 02:33 PM
cenzo's Avatar
cenzo
Default Goop
You might give "Goop" a try. Read the directions carefully. Goop is a contact cement with some flexibility and thickness. Clean both surfaces as best you can, then apply cement and allow drying time per directions. Press together firmly - no clamping should be necessary. Another set of hands is most helpful.
Old Nov 21, 2005 | 02:56 PM
bennettrp's Avatar
bennettrp
St. Jude Donor '06-'07-'08-'09-'10,'13-'14,'19-'20-'21-'22
How about Gorilla Glue? That stuff seems to hold about anything. Also pretty expensive at Ace.
Old Nov 21, 2005 | 03:04 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
mine did the same thing.
silicone sealer will NOT hold!
I used JB weld, I fixed it over a year and a half ago and it's still good!
Old Nov 21, 2005 | 03:19 PM
JCsSilverVette
Its a 98, Yeah i've also heard silicone won't hold
Old Nov 21, 2005 | 03:26 PM
JCsSilverVette
With the JB Weld how did you keep the glass to the top while it dried.
Old Nov 21, 2005 | 03:42 PM
RPOZ4Z's Avatar
RPOZ4Z
I used an old pillow and a blanket to keep the window in place.
Old Nov 21, 2005 | 03:46 PM
rapid robert's Avatar
rapid robert
I tried the silicone glue also. It just let go again the other day after about 8 mos. It stuck to the top and the glass but stretched like gum in the middle. This time I used 3M Scotch-Grip. I used duct tape to hold the window tight to the fabric. I put half on the top and half on the glass than used a wallpaler seam roller to get atight fit. Let it sit unlatched for two days to release the tension on the top by the back window. So far so good. I just did it friday. Wish I'd seen the JB stuff as I would have tried that.
Good luck and hope you find a solution.
Old Nov 21, 2005 | 05:15 PM
ProDesign's Avatar
ProDesign
You can glue the glass back to the top. Use 3M Super Weather strip Adhesive. It has a peel strenth of 35 lbs.
http://products3.3m.com/catalog/us/e...er/output_html
You apply adhesive to both fabric and glass, let dry a few minutes and then press together. Before using the glue, clean the glass and remove the old bond strip (1" liner) between glass and fabric. .
Old Nov 21, 2005 | 11:08 PM
Awsum98's Avatar
Awsum98
that happened to my 98' i glued it back with cyanoacylate glue ( used for plastic models) sort of a super superglue !! it bonds instantly and lasts for the past 2 yrs. just put a little strip on the glue strip then attach the glass it will bond instantly. be sure to stretch the top while applying , it will not move once the two parts touch !!!
To Convt. Top
