Need Z06 Alignment Specs
Old Nov 21, 2005 | 06:37 PM
DJMRTS's Avatar
DJMRTS
Default Need Z06 Alignment Specs
Can someone please give me stock C5 Z06 alignment specs! Also what you might recomend to be a bit more aggressive for cornering without increasing tire wear. I have a lowered '99 Vert with Z06 springs, Bilstein Sports, and recently went back to Z06 sway bars from T-1's. Thanks
Old Nov 21, 2005 | 06:54 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
RPO Operation Service Preferred Tolerance
All Front Individual Toe 0.04 +/- 0.10
All Front Sum Toe 0.08 +/- 0.20
All Steering Wheel Angle 0 +/- 1.0
FE1 & FE3 Front Individual Caster 7.4 +/- 0.5
FE1 & FE3 Front Cross Caster Within +/- 0.5 --
FE1 & FE3 Front Individual Camber -0.2 +/- 0.5
FE1 & FE3 Front Cross Camber Within +/-0.5 --
FE4 (Z06) Front Individual Caster 6.9 +/- 0.5
FE4 (Z06) Front Cross Caster Within +/- 0.5 --
FE4 (Z06) Front Individual Camber -0.7 +/- 0.5
FE4 (Z06) Front Cross Camber Within +/- 0.5 --
Old Nov 21, 2005 | 07:03 PM
DJMRTS's Avatar
DJMRTS
Ttt
Old Nov 21, 2005 | 07:27 PM
User 81424's Avatar
User 81424
Wheel Alignment Specifications
RPO
Operation
Service Preferred
Tolerance
Front Alignment Specifications
All
+ 0.04
+/- 0.10
All
Front Sum Toe
+ 0.08
+/- 0.20
All
0.0
+/- 1.0
FE1 & FE3
+ 7.4
+/- 0.5
FE1 & FE3
Front Cross Caster
Within +/- 0.5
FE1 & FE3
- 0.20
+/- 0.5
FE1 & FE3
Front Cross Camber
Within +/-0.5
FE4 (Z06)
+ 6.9
+/- 0.5
FE4 (Z06)
Front Cross Caster
Within +/- 0.5
FE4 (Z06)
- 0.70
+/- 0.5
FE4 (Z06)
Front Cross Camber
Within +/- 0.5
Rear Alignment Specifications
All
Rear Individual Toe
- 0.01
+/- 0.10
All
Rear Sum Toe
- 0.02
+/- 0.20
All
Rear Thrust Angle
0.0
+/- 0.10
FE1 & FE3
Rear Individual Camber
- 0.18
+/- 0.5
FE1 & FE3
Rear Cross Camber
Within +/- 0.5
FE4 (Z06)
- 0.68
+/- 0.5
FE4 (Z06)
Rear Cross Camber
Within +/- 0.5
In the Z06 section we have an extensive FAQ.
Old Nov 21, 2005 | 09:36 PM
DJMRTS's Avatar
DJMRTS
RPO
Operation
Service Preferred
Tolerance
All
+ 0.04
+/- 0.10
All
Front Sum Toe
+ 0.08
+/- 0.20
All
0.0
+/- 1.0
FE1 & FE3
+ 7.4
+/- 0.5
FE1 & FE3
Front Cross Caster
Within +/- 0.5
FE1 & FE3
- 0.20
+/- 0.5
FE1 & FE3
Front Cross Camber
Within +/-0.5
FE4 (Z06)
+ 6.9
+/- 0.5
FE4 (Z06)
Front Cross Caster
Within +/- 0.5
FE4 (Z06)
- 0.70
+/- 0.5
FE4 (Z06)
Front Cross Camber
Within +/- 0.5
All
Rear Individual Toe
- 0.01
+/- 0.10
All
Rear Sum Toe
- 0.02
+/- 0.20
All
Rear Thrust Angle
0.0
+/- 0.10
FE1 & FE3
- 0.18
+/- 0.5
FE1 & FE3
Rear Cross Camber
Within +/- 0.5
FE4 (Z06)
- 0.68
+/- 0.5
FE4 (Z06)
Rear Cross Camber
Within +/- 0.5
THANKS!!!!
To Need Z06 Alignment Specs
