Help, Random, Multiple Misfires after New Plugs
Old Nov 23, 2005 | 05:39 PM
CAPTKEN28's Avatar
CAPTKEN28
Default Help, Random, Multiple Misfires after New Plugs
Hey Guys,
I just installed new plugs on my 25k mile 2004 Z06. I used NGK Tr55's. The install was pretty easy and all was well until i decided to test drive the car.
When in idle car revs smootly and does not misfire.
When under load around 4k rpm it misfires bad and throws the P0300 code multiple misfires..
Whats wrong
I appraciate your help
Ken
Old Nov 23, 2005 | 05:41 PM
CAPTKEN28's Avatar
CAPTKEN28
Also car is stock, but has a predator tune...I already put the car back to stock tune...but same problems.
Old Nov 23, 2005 | 05:54 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
well........ it HAS to be something related to the new spark plug install.
check your spark plug wire connections.
make sure all plug wires are securely pluged into the spark plugs (push until they "click" into the plug).
make sure you didn't damage a plug wire while you were unpluging them.
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
All you did was replace the plugs? Nothing else? As posted above make sure the wires are plugged into the plugs. Then, if that's the case you may have broken a wire when removing them from the old plugs. I would check the wires first and then check for a broken (cracked) plug.
Old Nov 23, 2005 | 06:17 PM
CAPTKEN28's Avatar
CAPTKEN28
When tightening the rear driver side (the hardest plug) it made a "cracking" sound when i was tightening it....
maybe this is the case.
But wouldn;t a cracked plug make the engine run bad...when in N the car revs nicely...only under load does it misfire.
Old Nov 23, 2005 | 06:18 PM
CAPTKEN28's Avatar
CAPTKEN28
I am going outside right now...now thats its dark to see if there is any arcing......brb
6Speeder's Avatar
6Speeder
As above said, check wires. But, what did you gap them to?
Maybe too much gap.
Looks like you posted the probable problem just as I posted. Check that plug. If it's damaged it'll act up under load.
Old Nov 23, 2005 | 06:22 PM
16Again's Avatar
16Again
I think you may have identified your problem if all the wires are correctly snapped on. No,the plug might be fine under light or normal load and once it's stressed a little the mis-fire shows up.
Old Nov 23, 2005 | 06:39 PM
CAPTKEN28's Avatar
CAPTKEN28
Ok i rechecked to make sure all wires were on tight. and took it out on a lil spin...For the first 10 min of hard driving i experianced no misfires. But once the engine was warmed up 192* i only experianced misfires under WOT and past 5k rpm. So it might be the last plug. And i will check it once the car has cooled down enough (its 50 deg so it will be about 30 min.) If it is cracked i will go get another one and follow up...
Thanks guys...You Rock
CAPTKEN28's Avatar
CAPTKEN28
I did not check the gaps...They state they are gap'd to specs from the factory...;
Hummmm
Old Nov 23, 2005 | 06:47 PM
Z06Doug's Avatar
Z06Doug
Yeah sounds like a bad plug of some sort. If you heard one crack as you tightened it down, that would be the first one I would check.
Also did you use a torque wrench or anything to tighten them with, or just tighten them down hard? (I'd go find a tq wrench and find out what they should be torque'd too personally) I would also pull them and make sure they are gapped correctly (usually they are, but occasionally I've found some that aren't).
Good luck.
(PS. why are you changing them after only 25k miles, shouldn't they be good for alot longer?)
Old Nov 23, 2005 | 06:49 PM
CAPTKEN28's Avatar
CAPTKEN28
I will be pulling the drive side rear one in about 15 min.....I will be replacing it with a new one just to be sure.
I cant fit a torque wrench in the small confines so i just tighten them until they are snug..
I will have the autoparts store check the gap on the new plug i buy....
I'll be back in 30 min
Old Nov 23, 2005 | 06:50 PM
dpd's Avatar
dpd
cracking noise during install? willing to bet the plug is cracked.other possibilities.did you feel the plug wires"click" when you plugged them back on?are you sure the heat sheilds didn't cut in to the plug boots? more than likely your c"cracking noise"plug is arcing to the heat sheild under load.
Old Nov 23, 2005 | 07:28 PM
ST0CKER's Avatar
ST0CKER
yep cracked ceramic insulator. Heat=resistance. As it heats up it'll show its head.
daev
Old Nov 23, 2005 | 09:20 PM
Mike Mercury's Avatar
Mike Mercury
Hummmm
My Delco Iridiums claimed that as well. 7 of them were perfect, one was w-a-y- off.
Old Nov 23, 2005 | 10:18 PM
Gonzo's Avatar
Gonzo
interesting, I wonder if all the ones used in maunfacture are gapped correctly, 1 in 8 is not good, with that ratio we all may have one poorly gapped plug....
Old Nov 23, 2005 | 10:22 PM
Mike Mercury
the incorrect plug was gapped too narrow. I believe it was jolted pretty good in shipment/handling and was slammed onto the electrode.
To Help, Random, Multiple Misfires after New Plugs
Old Nov 23, 2005 | 10:25 PM
CAPTKEN28's Avatar
CAPTKEN28
Update:
Old Nov 23, 2005 | 10:29 PM
CAPTKEN28's Avatar
CAPTKEN28
Update:
I went and got another plug, waited until the engine was cool to touch before tackling the driver side rear plug. As i thought and with your helpful comments i took the plug wire off and heard some particles hit the ground and as i took out the plug the ceramic was cracked badly. Put new plug in and it was time to test drive...
I will post pics of my old (origional plugs) and the one that was cracked later but the problem is solved!
I even got to play with a S55 AMG and pulled nicely on him. But let me tell you those sure get out of the hole quick...
THANK YOU THANK YOU THANK YOU
Beers for everyone!
Old Nov 23, 2005 | 10:41 PM
16Again's Avatar
16Again
Glad it worked out for you.
