code 1214
Old Nov 24, 2005 | 05:58 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default code 1214
I get this code every once and a while. Service ABS, Service Traction Control comes on the DIC comes on afterwards. I clear the code an I am good for a couple more days. Is this something that my tuner can tune out, or do really have an issue.
Old Nov 24, 2005 | 11:47 AM
ICULUKN-C5's Avatar
ICULUKN-C5
okay... 1214 is Injection Pump Timing Offset
what the hell is that?
Old Nov 24, 2005 | 12:08 PM
turboc5's Avatar
turboc5
sounds like a code for a dissel. Do you have a dissel vette? Torque monster
Old Nov 24, 2005 | 12:28 PM
ICULUKN-C5's Avatar
ICULUKN-C5
I have a bunch of torque.. with the TT's and the nitrous, but .... not sure if it is a tuning issue or a part malfunction
Old Nov 24, 2005 | 03:17 PM
ICULUKN-C5's Avatar
ICULUKN-C5
ttt
Old Nov 24, 2005 | 08:15 PM
ICULUKN-C5's Avatar
ICULUKN-C5
ttt
Old Nov 24, 2005 | 09:49 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
http://forums.corvetteforum.com/show...214&forum_id=1
Old Nov 25, 2005 | 02:17 AM
rikhek's Avatar
rikhek
You're probably going to be in the market for a EBTCM (Electronic Braking Traction Control Module). Been there done that.... not cheap. In the $700 range.
Old Nov 25, 2005 | 05:05 PM
Fast98's Avatar
Fast98
Yup ebcm big bucks
Old Nov 25, 2005 | 07:43 PM
fdxpilot's Avatar
fdxpilot
I had that code, and in my case, it was a new BPMV (Brake Pressure Modulating valve.) Don't know the price, as it was fixed under my extended warranty.
Old Nov 25, 2005 | 07:58 PM
dpd's Avatar
dpd
1214 is a solenoid valve relay/coil circuit fault.the solenoid relay is inside the ebcm.if it's bad you need a ebcm.i would check the connector on the pump for corrosion and make sure the ground wire on the side of the pump is clean and tight.if all is ok,most liely a ebcm going south.
To code 1214
