Replacing Rear Wheel Studs
Old Nov 24, 2005 | 12:12 PM
Just Enough's Avatar
Just Enough
Default Replacing Rear Wheel Studs
Can the rear wheel studs be replaced on the car? I want to install longer studs and don't know how much disassembly is necessary. Thanks in advance.
Old Nov 24, 2005 | 12:25 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
You gotta take the wheel bearing off the car to replace the studs.
VR
Old Nov 24, 2005 | 01:55 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I stripped one of my rear studs at a race in 2004. To replace it, I took off the whole rear spindle, then took the wheel bearing assembly out of the spindle (which is attached with three torx bolts), and replaced the whole wheel bearing with a new one. If your wheel bearing is okay, it would be fairly easy to use a press or vice to get the studs out of the wheel bearing assembly once it is off the spindle.
That said, I have read on this forum where some guys actually drill a hole through the parking brake plate on the inside of the rear wheel and press the studs off with the wheel bearing assembly on the car. I wasn't brave enough to try that.
Here is a pic of losing one of the three torx bolts once the spindle was off the car:
And the cover plate and wheel bearing assembly after they have been removed from the spindle:
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 24, 2005 | 04:35 PM
Just Enough
Great info and pictures. Thank you vetterdstr & Subdriver.
Old Nov 24, 2005 | 05:08 PM
IT L GO's Avatar
IT L GO
See how Lou at LG Motorsports does it at this thread
http://www.z06vette.com/forums/showt...ht=wheel+studs
To Replacing Rear Wheel Studs
