Check Engine Question
Old Nov 27, 2005 | 02:43 PM
glind46677's Avatar
glind46677
Default Check Engine Question
I drove my 04 in the garage about two weeks ago no light. When I cranked it today and started to drive the check engine light came on and stayed on. Whats that all about??? Help
Old Nov 27, 2005 | 03:01 PM
Goonie's Avatar
Goonie
Key in the ON position...
Hold Options button and press Fuel button 4 times...
Codes will come up... it will go through automatically unless u press Reset once, then you can scroll up and down em by using the top four buttoms.
Post codes here...
Old Nov 27, 2005 | 03:29 PM
dpd's Avatar
dpd
Post codes here...
Old Nov 27, 2005 | 05:51 PM
glind46677's Avatar
glind46677
Default Code says 10-pcm 2 codes
10-pcm 2 codes What does that mean???????????????
Old Nov 27, 2005 | 05:59 PM
Goonie's Avatar
Goonie
10 -PCM powertrain
2 codes you got 2 errors with the powertrain.
when you see that press the 2nd from the top i believe and youll get the list of codes...
the top for buttons are your controls in that menu... top 2 shuffle inside a certain area and the 3 and 4 buttons shuffle through the different areas.
theres a link ill find it
Old Nov 27, 2005 | 06:02 PM
Goonie's Avatar
Goonie
Heres everything you need to know, enjoy!
http://www.c5forum.com/ayc/dtcdic.php
Old Nov 27, 2005 | 06:12 PM
glind46677's Avatar
glind46677
Thanks Goonie
Old Nov 27, 2005 | 06:17 PM
glind46677's Avatar
glind46677
Goonie: One more question will I have to take the car to a dealer to have it fixed ?
Old Nov 27, 2005 | 11:54 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
For the most part, codes tell you what is wrong and once you correct the problem, you clear the codes and problem solved!
Here is a very good web site for codes!
This is the absolute best C5 Code web site!!!
http://www.corvettedoctor.com/Codes_Page.htm
You can display each code in the PCM. Make sure that you include if they are H history or C current! Post the DTC. it will be something like PCM 1233 H or PCM 0300 C.
If you have not ever read and cleared your codes, you may have a ton of junk codes. Clear them, take her for a drive and see what comes back.
Post the most current codes and we will point you in the right direction!
You dont need NO STINKEN Stealer!
Bill C
To Check Engine Question
