Trailer Tie-downs
Old Dec 1, 2005 | 02:01 PM
ThissenW's Avatar
ThissenW
Default Trailer Tie-downs
What's the correct way to tie-down a C5 on a trailer? Does anyone have any documentation on this? Thanks.
Old Dec 1, 2005 | 02:21 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I have seen different answers to this. Some people save to go around the a-arms while others say that might bend them. I have seen straps for the tires, but never used them.
When I towed I used tie down with ratchet buckles and alxe straps. The straps were the best. Basically they are strong material that use can swing around the alxe or whatever. You then can hook your tie downs right to the end of them. It is just much easier to be under the car with those then with the tie down.
One thing I do know in the back use the criss cross method. You will want the left side tie down to be attached to the right side of the car and the right side attached to the left side.
hoepfully someone else will chime in and give better advice...
Old Dec 1, 2005 | 02:50 PM
AU N EGL's Avatar
AU N EGL
Here is a thread in the C5 Z06 forum about trailering
http://forums.corvetteforum.com/show...38&forum_id=49
Old Dec 1, 2005 | 03:37 PM
GUSTO14's Avatar
GUSTO14
A lot of good information there Tom. That's exactly how I tie mine down. I do however run my cars up on a set of 2X10's about 3 feet long to give me a little more room under the car to reach the tiedown points. It also adds a little clearance between the straps and the spoilers in the front.
A good trailer is worth every bit you spend on it, and if it's enclosed can even double as a garage in a pinch.
Good luck... GUSTO
Old Dec 3, 2005 | 02:18 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I use the same method described by Tom, the
X
X
using T-hooks attached to the tie down points on the siderails. I've towed my car probably 30k miles to various races in the last three years without a problem.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To Trailer Tie-downs
