Replacing Wheel bearings
Old Dec 2, 2005 | 12:42 AM
sambarnett's Avatar
sambarnett
Default Replacing Wheel bearings
It looks like there are like 3 torx bolts behind the hub and it would just pull out. Is it that simple? Does it just slide out or would I need a slide hammer? Any words of wisdom?
Sam
Old Dec 2, 2005 | 02:09 AM
99FewteRC5's Avatar
99FewteRC5
just slides out after the 3 torx bolts are removed...
Old Dec 2, 2005 | 02:21 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
#55 torx and autozone.com where they are cheap and OEM
Old Dec 2, 2005 | 08:38 AM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
Just drop the lower ball joint low enough to reach the bottom torx.
Old Dec 2, 2005 | 08:59 AM
BAD_TCR's Avatar
BAD_TCR
...and there is the key..sure it comes out with all the torx screws removed, but you got to get to the last one. I rented a ball joint pop'er from Autozone, but you might be able to pop it without it.
Old Dec 2, 2005 | 10:22 AM
DidntSettle's Avatar
DidntSettle
From: Manchester - Political correctness is tyranny with manners.
http://www.jakelatham.com/c5/misc/C5...el_Bearing.doc
Old Dec 2, 2005 | 12:25 PM
sambarnett's Avatar
sambarnett
Thanks for the help guys.
Sam
Old Dec 2, 2005 | 02:45 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
i've done about a dozen if you get stuck send me a pm, jake latham's site has some great info
Old Dec 3, 2005 | 09:30 AM
davidfarmer's Avatar
davidfarmer
I've done a buch and they always **** me off!
Old Dec 3, 2005 | 01:59 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Ya, it really bothers me that they put the lower torx bolt right behind the lower ball joint. Seems like there is enough room that they could have put the bolts in a place you could get to them without splitting the lower ball joint.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Dec 4, 2005 | 01:15 PM
84bronzevette's Avatar
84bronzevette
To separate the knuckle from the ball joint without special tool loosen the nut then smack the knuckle hard with a heavy hammer dead on. One or two hits is usually sufficient to separate taper fit. You will probably leave a slight impression in the aluminum but it is barely noticeable. Avoid inaccurate hits as damage to stud or even fender could result!
Old Dec 4, 2005 | 01:28 PM
dmtnt's Avatar
dmtnt
Or use a block of wood on the a-arm and hit that with the hammer.
To Replacing Wheel bearings
