Need help with "creaking" front end......
Old Dec 2, 2005 | 04:57 PM
carpe dm's Avatar
carpe dm
Default Need help with "creaking" front end......
I recently had an alignment done and new tires installed. Now, there is a screech/creaking sound coming from the driver's side front wheel area. It makes the sound when the wheel is turned left or right. I jacked up the front and found that it does not make the sound when the weight is off the car, but does, when on the road. It sounds terrible and I can't imagine what it could be, so I have come to you folks for help. Thanks.
Old Dec 2, 2005 | 07:00 PM
carpe dm's Avatar
carpe dm
ttt help
Old Dec 2, 2005 | 07:39 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Check the end links on your sway bar. Are they stock? They may need lubrication.
Old Dec 2, 2005 | 10:06 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
http://forums.corvetteforum.com/show....php?t=1241734
Old Dec 2, 2005 | 10:10 PM
jjcslynn's Avatar
jjcslynn
Did you check the wheel bearing for play?
Old Dec 3, 2005 | 11:47 AM
carpe dm's Avatar
carpe dm
The bearings see, OK, and the sound seems to be related to the steering and occurs when the wheel is turned right or left.?????
Old Dec 5, 2005 | 05:37 PM
carpe dm's Avatar
carpe dm
It was the stabilizer (or sway bar) bushings. I dropped the bar enough to get the bushings off, applied synthetic grease, reinstalled, and my noise is gone!! Thanks to all, I can now drive in peace.
Old Dec 6, 2005 | 12:04 AM
edensknight's Avatar
edensknight
Awesome! The creaking endlinks is a common problem. Glad you figured it out. Enjoy.
To Need help with "creaking" front end......
