How thick are they??
Old Dec 2, 2005 | 09:45 PM
1coolC2's Avatar
1coolC2
Default How thick are they??
Can someone provide me with the thickness of the rear rotors at the hub (i.e the mounting surface). I am trying to mock up upgrading a C4 hub to accept the C5/C6 rotor but need to know how much it adds/loses to track width. Thanks. Check out the link showing the project I am working on.
http://forums.corvetteforum.com/show...516&forum_id=4
Old Dec 3, 2005 | 07:16 AM
1coolC2's Avatar
1coolC2
Does anyone have an old set of rotors they are willing to part with cheap??
Old Dec 3, 2005 | 10:31 AM
EHS's Avatar
EHS
Link doesn't work.
Old Dec 3, 2005 | 11:21 AM
DPG's Avatar
DPG
St. Jude Donor '06
when are you planing on mocking them up. I will have a set of used Z06 rotors sometime this winter. If you need them right away, i can see if i can just swap my old ones out sooner. Just pay shipping and they are yours. Let me know and i'll see what i can do for ya
Dave
Old Dec 3, 2005 | 11:45 AM
EHS's Avatar
EHS
Dave is a prince.
Old Dec 3, 2005 | 11:47 AM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
I am throwing out some Baer Eradispeeds this winter as well.
Old Dec 3, 2005 | 05:28 PM
1coolC2's Avatar
1coolC2
Dont know why the link did not work ...try this
Dave, sent you an email...thanks
Old Dec 4, 2005 | 08:37 AM
EHS's Avatar
EHS
Works now, thanks.
Looks like you're doing a beautiful job.
Old Dec 4, 2005 | 12:17 PM
leaftye's Avatar
leaftye
Sorry, this is all I thought to measure:
http://forums.corvetteforum.com/showthread.php?t=984927
C5 Suspension[U]
Brake Rotor Dimensions-front
3 cm, 2 mm --- rotor thickness --- Source
7 cm --- center hole diameter --- Source
7 cm --- lug to lug spacing --- Source
11 cm --- lug diameter...don't know how to say from two lugs across rotor to single lug. Imagine an acute triangle if dots were connected --- Source
3 cm, 8 mm --- inside face of hub to rotor surface --- Source
19 cm --- inner hub diameter --- Source
21 cm, 7 mm --- out hub diameter --- Source
32 cm, 5 mm --- rotor diameter --- Source
Brake Rotor Dimensions-rear -- dimensions that are same as front are not repeated
2 cm, 6 mm --- rotor thickness --- Source
4 cm, 2 mm --- inside face of hub to rotor surface --- Source
20 cm, 2 mm --- out hub diameter --- Source
30 cm, 5 mm --- rotor diameter --- Source
If I ever remember where I put those rotors, I'll measure them for you.
To How thick are they??
