Turn signal question?
You'll get three main ways to change the bulb. Some guys like to go in through the brake duct, some open the panel beneath the front. the one that works for me is:
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It unscrews counter clockwise but it has a plastic clip which you need to squeeze to release it. Change the bulb. Reseat the bulb holder and turn until it clicks back in place. Put the plastic housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
10 minute job.
Best of luck but don't pay the dealer $$$$$$$ for a simple fix.
2000 Chevrolet/Geo Corvette
Park/Turn Signal/Side Marker Lamp Bulb Replacement
Removal Procedure
Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the front fascia lower closeout panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers.
Release the brake caliper cooling duct from the front fascia, then reposition the duct.
Remove the appropriate socket from the lamp assembly.
Remove the bulb from the socket.
Installation Procedure
Install the bulb to the socket.
Install the socket to the lamp assembly.
Position the brake caliper cooling duct to the front fascia and push the duct toward the fascia to secure.
Install the front fascia lower closeout panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers.
Lower the vehicle.
