Code PO-0336 Driving Me Crazy...LS2 (427)
Old Dec 4, 2005 | 11:56 PM
RODMAN1966's Avatar
RODMAN1966
Default Code PO-0336 Driving Me Crazy...LS2 (427)
Installed LS2 STROKER 427 IN 98 VETTE.
WILL NOT RUN WHEN CODE PO 0336 HITS, like MAYBE ON THREE CLY.
CRANKSHAFT POSTION LOCATING, CAN NOT BE RELEARNED ON 98 VETTE
COMES IN SHORTLY AFTER CAR IS STARTED, CAR RUNS GREAT UP TO THIS POINT.
HAS ANYONE ELSE IN THE COUNTRY HAD THIS PROBLEM.
??????????? CAR IS NOT DRIVEABLE.
I CLEAR CODES LET CAR SIT 10 MINUTES, CAR STARTS REVS UP FINE IDLES GREAT. THEM 2 MINUTES LATER, WITHOUT MOVING CAR GO TO REV IT UP, RUNS LIKE SH..........T
COULD THE CRANK SENOR BE TO FAR FROM RELUCTOR WHEEL, BY THE WAY CALLIES CRANK, NO END PLAY GOOD WHEEL, TWO DIFFERENT CRANK SENSORS. OR CAM SENSOR PRO BLEM?
Old Dec 5, 2005 | 02:42 AM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
Where did your block come from. I know Jason at TSP had the same problem with his ls2 402. Problem was the crank sensor hole was machined in the wrong place. It was not close enough to the crank, or it was off to the side a little and couldn't get a good reading. Sounds like the exact same problem. I know his would start but sound like it was running on every other cylinder. He fixed the problem, but i am not sure how, try calling him on Tuesday to see if has can help
Old Dec 5, 2005 | 10:02 AM
RODMAN1966's Avatar
RODMAN1966
Default Still Looking For A Solution
I Talked To Jason Already He Had A Different Issue Causeing Problem. Block Was Not His Problem, I Don't Think.
Thanks...
Old Dec 6, 2005 | 10:58 PM
RODMAN1966's Avatar
RODMAN1966
ttt
Old Jan 24, 2006 | 02:59 PM
hpcubed's Avatar
hpcubed
Any luck figuring out the problem? I am in a similar situation.
Old Jan 24, 2006 | 05:12 PM
dpd's Avatar
dpd
has anybodytried a crank relearn with a tech II/modis or any type of scanner that will allow you to relearn the crank?
Old Jan 24, 2006 | 11:00 PM
chriskaw7r's Avatar
chriskaw7r
What kind of crankshaft is it? I m just guessing here. I know there is different number of teeth on the newer LS2 type engines.
To Code PO-0336 Driving Me Crazy...LS2 (427)
