Battery Tender?
Old Dec 5, 2005 | 12:54 AM
lioninavette's Avatar
lioninavette
From: Ponderables, yes. My opinion, not totally. Preaching...I don't have a pulpit. Fact and generalizations about what I am reading on behalf of what you tell me...absolutely.
Default Battery Tender?
Snow on ground already...looks like it is going to be a long winter.
Never used a battery tender before...which one does anyone recommend? Price?
I always drove the car through the winter, but with this early snow, don't think it will be an option for a little while (more snow on way tomorrow).
Old Dec 5, 2005 | 02:51 AM
diviniti's Avatar
diviniti
St. Jude Donor '05
Local auto parts stores here sell them. Such as Murrays, Auto Zone, Pep Boys. Just goto one of them and look in the battery section where the battery parts are.
Old Dec 5, 2005 | 06:23 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
$25 at Sears
Old Dec 5, 2005 | 07:08 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
The Deltron "Battery Tender" is usually $49.95 at most of the stores noted in #2 thread.
Old Dec 5, 2005 | 10:52 AM
vette747's Avatar
vette747
There are two type of battery tender. The first one, including solar system, does not stop when battery is full. Since the C5 drains less than 30 milliamps, this type of charger can over charge the battery. I recommend a battery tender that stops when battery is full and automatically restart when required.
Old Dec 5, 2005 | 11:00 AM
Shylor's Avatar
Shylor
Sears here also. The manual has wrong information about it but the product works greats.
Old Dec 5, 2005 | 01:06 PM
GUSTO14's Avatar
GUSTO14
There are a lot of these things on the market right now and some of them are very cheap. Some are cheap for a good reason… they're nothing but a small battery charger. If cheap is your goal, this is the way to go, but you owe it to yourself to verify the features of the unit.
The following are things you should look for and expect in a charger you will be leaving connected and unattended for extended periods of time. If it isn't in the writing, it probably isn't there and might explain the cheaper price.
1. Charger/Maintainer - it charges the battery and turns itself off when the battery reaches full charge, monitors the voltage and turns itself back on if the battery drops below a certain level.
2. Conditioner - desulphates the battery…
"Every element known to man has a magnetic moment at a resonant frequency ie, a point at which the chemical bonds that hold the molecules together to form a crystal can be broken. Sulphation, the number one cause of early battery failure, is simply crystals of lead sulphate (PbSO4) which have formed on the lead storage plates in a lead-acid type battery.
When a battery is used over time, improperly charged (over/under) or allowed to self discharge (as occurs during storage/non-use), these crystals build up on the battery's storage plates. This prevents the battery from ever again being fully charged and able to deliver their full power/capacity. "
3. It should also be polarity, short circuit and temperature protected.
The bottom line is you can get all of these features for less than $50, and the safety of your vehicle and home as well as peace of mind, ought to be worth that much. Deltran and BatteryMINDer are just two that have these features.
By the way, never charge a frozen battery or one that is over 120 degrees F.
Good luck with your decision… GUSTO
Old Dec 5, 2005 | 01:12 PM
Oldvetter's Avatar
Oldvetter
I just bought one at WallMart, $17.44
Love your avatar, I am a Penn State Grad also.
WE ARE PENN STATE ! 10-1
BIG TEN CHAMPS
Ranked #3!!!
Old Dec 5, 2005 | 02:08 PM
tiojames's Avatar
tiojames
Default battery tender
Check Harbor Freight- thet have one with the late technology to only supply battery with what it needs. Cost is $10.
Old Dec 5, 2005 | 03:46 PM
GUSTO14's Avatar
GUSTO14
Harbor Freight does not have one that desulphates a battery and the $10 one does not have automatic shut-off. Granted it's a low amp solar charger, but it only shuts off... when the lights go out.
GUSTO
Old Dec 5, 2005 | 10:51 PM
rws.1's Avatar
rws.1
this is the one to buy.... at Harbor Freight. I have two and bought two fo rmy brother.... they work great!
AUTOMATIC BATTERY FLOAT CHARGER
Skip the aggravation of a jump-start by keeping your vehicle's battery fully charged. Use on 12V batteries while in storage or during cold weather. The floating circuit maintains a full charge without overcharging. Includes automatic safety shut off.
Leads: 10 ft. overall length
ITEM 42292-1VGA $7.49
Old Dec 5, 2005 | 11:06 PM
GUSTO14's Avatar
GUSTO14
Originally Posted by rws.1
...AUTOMATIC BATTERY FLOAT CHARGER
Thanks Richard... when I looked earlier on their web site I could only get a Solar Charger to come up for $10, but with the part number I found it. There are lots of these out there, but none at these prices that also desulphate. If you just want to keep it charged, these will probably do the trick...
By the way, the Solar Charger does come in handy for keeping a battery charged without running power to the vehicle, I have one for that purpose. But alas they don't desulfate either. As I mentioned earlier, you can get all the features I listed for under $50 (~$39.99)... but not in a $10 one.
GUSTO
Old Dec 6, 2005 | 08:23 PM
RonJ's Avatar
RonJ
Wal-Mart, they have a floating charger/maintainer made by Schumacher.
I have two of them, happy with both.
RonJ ...
Old Dec 7, 2005 | 03:09 AM
cebars's Avatar
cebars
Thanks for the info re desulfating ability. What make and model of battery tender are you using?
Old Dec 7, 2005 | 07:15 AM
C5XTASY's Avatar
C5XTASY
What he is discussing in this thread appears to not be the ability to de-sulphate, but to ensure the battery does not sulphate during storage by keeping battery voltage proper and constant during storage without continuous charging....big difference.
Fleet Farm sell maintainers for $20-25. They work great. I've never had a battery failure, either on my boats, or C5, and those batteries are placed on these every winter, all winter.
Ed
Old Dec 7, 2005 | 08:31 AM
Tigershark3's Avatar
Tigershark3
I've got 2 myself. Harbor Freight had them on sale last week for an amazing low price of $5. These are floaters and do shut off.
Old Dec 7, 2005 | 09:23 AM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Battery tender plus.I got mine at pep boys their is a cheaper battery tender model but that"s the wrong one it has to be the plus one
To Battery Tender?
Old Dec 10, 2005 | 01:28 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Just ordered two at Battery mart 29 ea and 6 bucks shipping. I wouldn't go for a 5 dollar charger as the store needs to make money on it and the manufacturer does so what is the actual cost 2 bucks. Deltran has 5 year warranty also. Pep Boys was 40 bucks
Old Dec 10, 2005 | 04:59 PM
GUSTO14's Avatar
GUSTO14
John, I must apologize, I thought all of the Deltrans incorporated the capability to desulphate. It appears that the $29 one does not if that is important. This one does have the capability...
http://www.batterymart.com/battery.mv?p=DEL-021-0128
... it's $43.95
The Battery MINDer that has the desulphation capability is this one...
http://www.batterymart.com/battery.mv?p=VDC-12112
... it's $39.90... it's the one I have.
Deltran makes a good Charger/Maintainer regardless.
Good luck... GUSTO
Old Dec 10, 2005 | 05:05 PM
John Shiels
to late now unless I can call them Monday
just looked out of stock till spring 2006
