Crank pulley separated from damper?
Old Dec 6, 2005 | 04:15 PM
1998Coupe's Avatar
1998Coupe
Default Crank pulley separated from damper?
I started hearing loud noiseses from the front of the car. The 6 rib pulley on the crankshaft lost it's pressed fit from the damper and moved back about 1/2". Has anyone else had this happen?
Old Dec 6, 2005 | 04:55 PM
C5dream's Avatar
C5dream
Yep happened to me on my 99. Might as well replace with an aftermarket ASP underdrive pulley.
Old Dec 6, 2005 | 06:50 PM
turboc5's Avatar
turboc5
Eventially happens to all c5's do a search and you will find all the answers to replacing it and why it goes bad. I would replace it asap though.
Old Dec 6, 2005 | 08:33 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
www.ls1howto.com for the 'how to', every few weeks a thread like this pops up
To Crank pulley separated from damper?
