Stock torque converter...stall?
Old Dec 8, 2005 | 09:50 AM
byte_me's Avatar
byte_me
Default Stock torque converter...stall?
Is there any stall to a stock TQ converter? looking at CAM spec's in relation to RPM's and some of them operate most effectively in the 2500 to 3000 RPM range (generally high lift, high duration #'s) and some of the more mild cams work in the 1300 to 1500 to start then up to 6000 or 6300 RPM respectively.
So, considering a stock A4, stock Torque converter and 3:15 gears I am trying to determine at what starting RPM range I should look for to get the sweet spot of the performance gain in a cam only upgrade.
Old Dec 8, 2005 | 10:47 AM
XPC5R's Avatar
XPC5R
Stock is around 1600-1800rpm stall. A 2400-2800rpm stall retains a lot of the stock feel, and will complement a moderate to mild cam very well.
Old Dec 8, 2005 | 10:52 AM
byte_me's Avatar
byte_me
Thanks for the info
To Stock torque converter...stall?
