Dyno Tune
Old Dec 9, 2005 | 07:49 AM
roboa20's Avatar
roboa20
Default Dyno Tune
What are the advantages of having a C5 Dyno Tuned....and what is ususally done. Does any forum memebers know of any shop in the Little Rock, AR area that does a Dyno Tune...THanks
Old Dec 9, 2005 | 08:03 AM
byte_me's Avatar
byte_me
Sorry, don't know any in your area...but...
A tune will use some type of ECM software to first baseline what is currently happening (air\fuel ratio etc...)then they can modify certain tables to adjust for performace. Bump up the timing some, remove torque management, shift firmness, set the fans lower for a 160* t-stat etc...
I can tell you that the tuner in my area has been able to get 15 to 20 HP out of a stock C5! It helps of course to have mods already done prior to a tune (long tube headers, cam\heads etc...) that way they can adjust for your new found improvements.
Hope this helps!
Old Mar 8, 2006 | 01:52 AM
hexagram13's Avatar
hexagram13
PMed you about TNC Performance in Little Rock.
To Dyno Tune
