codes
Old Dec 10, 2005 | 12:06 PM
hilton head 50th's Avatar
hilton head 50th
Default codes
Ck. engine light on.
Some info for your help
Fuel range shows "LOW" even tho the tank is 3/4 full
I have Lg headers with no cats
Several codes which show as history
U1160-H communication with LDCM What does this stand for?
10 PCM?
AIRDCM?
ARSCM?
Thanks in advance for your help as this driven me crazy
Old Dec 10, 2005 | 01:16 PM
djengr's Avatar
djengr
10 PCM?
AIRDCM?
ARSCM?
No cats, do you have an O2 simulator. Seems it should throw a current code to make CEL come on.
LDCM Is left door control module. Probably an intermitant loose connection, I get these as well and always with an History code.
Old Dec 10, 2005 | 01:44 PM
hilton head 50th
10 PCM?
AIRDCM?
ARSCM?
I do have the 02 simulators. No problem since Aug. instulation
Old Dec 10, 2005 | 04:05 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
10 PCM?
AIRDCM?
ARSCM?:
As stated above the U1160 loss of comm with the LDCM is the left door control module but the other codes are incomplete, for instance the 10 PCM has a 5 digit code after it that starts with the letter P followed by 4 numbers.
The next one should be AI RDCM - right door control module.
and AR SCM - Seat control module.
To codes
