aftermarket TRANS cooler..??
Old Dec 11, 2005 | 10:44 AM
idiedtrying's Avatar
idiedtrying
Default aftermarket TRANS cooler..??
is this a good idea??? because my tranny lines are cut and is leaking fluid, so im going to just cut it there and run hose to an aftermarket trans cooler... a BIGGER one,..
Old Dec 11, 2005 | 10:46 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Alot of people here run a bigger cooler. The A4 crowd does
Old Dec 11, 2005 | 11:34 AM
99 vett babycar's Avatar
99 vett babycar
I think a trani cooler is the BEST mod you can make on an A4 car - stock or not.
Old Dec 11, 2005 | 12:25 PM
2002 MATRIX SC's Avatar
2002 MATRIX SC
i agree 100%
Old Dec 11, 2005 | 12:47 PM
SFengineer's Avatar
SFengineer
if you do it, get the biggest. I got the second largest and now feeling like i shouldn't have skimped the extra 7 bucks
Old Dec 12, 2005 | 02:17 AM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
You guys that DO already have tranny coolers, where exactly did you mount them? And did you route the fluid lines only to the external cooler, or did you leave them going through the cooler AND the radiator besides?
I would think the radiator would run a lot cooler if it didn't have to deal with cooling down the tranny fluid.
Old Dec 12, 2005 | 04:33 PM
Dirty Howie's Avatar
Dirty Howie
Its done both ways.
If you splice into the radiator line make sure its the UPPER return line!
DH
Old Dec 12, 2005 | 05:28 PM
Rhode Warrior's Avatar
Rhode Warrior
Originally Posted by 2002 MATRIX SC
i agree 100%
Ditto, I have the B & M Supercooler.
I mounted mine in front of the A/C condenser and tied into the upper line on the radiator cooler.
Old Dec 13, 2005 | 04:14 PM
idiedtrying
so take both trans lines from the radiator, and then run both lines to the cooler, should i just plug the 2 holes in the radiator???
Old Dec 13, 2005 | 09:10 PM
frank dupuy's Avatar
frank dupuy
If you bypass the radiator like I did make sure to plug the tranny cooler holes in the radiator or they will become contaminated with dirt. You might want to change back in the future.
Old Dec 15, 2005 | 10:56 AM
idiedtrying
ok thanks
Old Dec 15, 2005 | 12:16 PM
IM QUIKR's Avatar
IM QUIKR
What I found is that I needed the radiator in series because the tranny temps headed north of 200 with the B&M 70264 alone. So what ever way you choose to go, monitor the tranny temps on the DIC in all seasons to make sure your temps stay low.
Old Dec 15, 2005 | 02:13 PM
MagikDraggin
Cruise-In V Veteran
I'm not sure I follow that at all. Pardon my asking, but why would the tranny temps rise if the radiator was no longer trying to cool the transmission fluid as well as the engine coolant?
That makes no sense. What am I missing here?
Old Dec 15, 2005 | 02:41 PM
IM QUIKR's Avatar
IM QUIKR
The transmission generates heat, correct? GM routes the fluid thru the radiator to cool it off(as well as bring it to temp faster). The friction from the TC is what generates the heat when it's unlocked. The 70264 was not efficient enough to counter the heat. So the fluid on my car runs thru the radiator to cool down and then one pass thru the B&M to cool it more, just as the install instruction state. If you use a larger cooler like an Earls or Setrab with a 2" core you may be able to cool it without using the radiator plus a cooler with a built in fan may work as well. I ran a B&M 70264 with a Spal pusher fan and the temps headed above 200 before I shut it down. Now with the new Dewitts radiator and the B&M in series my tranny temp is 160'ish at cruise. It's cold now but I'll know better once spring returns if the temp stays low in 80-90 degree ambient temps.
If your TC locks up sooner, this may not be a problem for you. I only offer my experience as a caution to those who mod their car and fail to monitor on the work.
Old Dec 15, 2005 | 02:53 PM
BLOWN'NC's Avatar
BLOWN'NC
Setrab with AN fittings here. It's mounted in front of the radiator and takes up about half the space. NO cooling problems either and I have the ATI twin kit too.
The tranny runs 160-80 whether it's cold or HOT. That's with a 2800 stall too.
To aftermarket TRANS cooler..??
