Car Runs Like Junk Help Please
Old Dec 12, 2005 | 09:38 PM
C5Josh's Avatar
C5Josh
Default Car Runs Like Junk Help Please
I am working on my brothers 1997 c5 A4 it has H/C, LT Headers, ls6 mainfoild and vortex rammer intake tunned and full install at A&A. The car almost dies and idles up and down and smells like it is running rich. The check engine light is on with code 0300. I took a compression test and I have 160 in all cylinders I did a full tune up Plugs TR55, MSD wires, PVC valve, fuel filter and cleaned the air cleaner. Car still runs the same with no change. The battery is good and the altenater is good. I am not sure what to check next. Please Help
Old Dec 12, 2005 | 10:00 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
i would guess you ripped one of the boots on the plug wires or it's not seated correctly, 0300 is a misfire code and the cel is prolly blinking when this occurs, try swapping in a set of the stock plug wires and see what happens
Old Dec 12, 2005 | 10:12 PM
C5Josh's Avatar
C5Josh
The car was doing the same thing before the tune up and the new wires. I was thinking the car just needed a good tune up but it did not change anything.
Old Dec 12, 2005 | 11:57 PM
cheemsaf's Avatar
cheemsaf
Check the actual spark plugs to make sure that they are not fouled and that they're not grounding out (i.e. that there is a gap there and it's the correct distance). They shouldn't be fouled since they're brand new. I accidently bumped one of my plugs when I installed it and closed the gap, so no spark = misfire. Also, try a sparkplug wire tester...hope you figure out what's wrong with it.
Old Dec 13, 2005 | 12:41 AM
jhong321's Avatar
jhong321
You can take it down to Synergy and have them check it out for. they are pretty close to you. They work on alot of the modded c5 and would know what to look for. Ask for rick he is the owner and a very nice guy to work with.
Old Dec 13, 2005 | 01:14 AM
PDQC5's Avatar
PDQC5
Have you tried calling A&A???
Old Dec 13, 2005 | 02:36 AM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
Check coil packs, and make sure they were plugged in the right order. If they were removed during a tune up or during install, the wires can be flipped around. Other then that, i sounds like you have tried everything else.
Dirty injectors?
Old Dec 13, 2005 | 06:20 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If your secondary ignition is not causing the issue, it could be valve train related. Check the springs, do a compression test. Low compression on one or more cylinders will cause the same mis-fire issues.
If the plugs and wires are in good shape, my bet is a bent valve or weak/broken valve spring.
Bill C
Old Dec 13, 2005 | 09:07 AM
IM QUIKR's Avatar
IM QUIKR
won't the visual on the spark plugs tell you which cylinder to focus on?
Old Dec 13, 2005 | 03:08 PM
C5Josh's Avatar
C5Josh
Default Help
I have checked everything that every one has suggested. The compression in all 8 cylinders is right at 160. All the plugs are brand new and I checked the gap on all of them and the wires are brand new and I checked them. A broken valve or something would give me low copression and I don't have that so I am not sure what is going on.
Old Dec 13, 2005 | 03:19 PM
SteveDoten's Avatar
SteveDoten
did you pull the v/c's and ck the springs?(15 minutes)
Old Dec 13, 2005 | 03:59 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Call SYNERGY if thet are in your area. Rick is a great guy and will not rip you off. They do a lot of work on these cars and will figure it out. Your tune is probably off. Mine was way off and Rick put a tune on it and it runs AWESOME now
Old Dec 13, 2005 | 05:13 PM
C5Josh's Avatar
C5Josh
hmm the vc's only take that long to pull?
Old Dec 13, 2005 | 07:20 PM
RoHo's Avatar
RoHo
Does the car have an oil catch can? mine started running $hity and the pet **** was cracked open, closed her up and every thing was back to normal. You also may want to check the drivers side headers to be sure your not touching wires
Old Dec 13, 2005 | 08:12 PM
SteveDoten's Avatar
SteveDoten
i'll give you a couple of more minutes for the '97 w/ perimeter bolts on the vc's, but w/ aftermarket heads i would assume those where long gone; 10 bolts for the coilpacks, 2 plugs, rem alt., loosen 8 vc bolts, ck it out
Old Dec 13, 2005 | 09:10 PM
C5Josh's Avatar
C5Josh
I am going to pull the valve covers and see if anything is wrong with the valve train. I also talked someone and they said I need to do a leak down test.
Old Dec 14, 2005 | 03:57 AM
#001 2001 Z06's Avatar
#001 2001 Z06
NCM, WSCC & SCC Member
Default www.synergymotorsports.net
1-510-796-3749
To Car Runs Like Junk Help Please
Old Dec 14, 2005 | 09:09 AM
Gordy M's Avatar
Gordy M
Find someone with good scanning software and take a 20-30 minute road test. It will tell you what is working and what are the problems. That way you know where to focus you attention. Other wise it is hit or mis till you find out the real culprit.
Old Dec 14, 2005 | 02:12 PM
C5Josh's Avatar
C5Josh
Hooked it up to the scanner and the number two cylinder had misfire 40 times.
Old Dec 14, 2005 | 02:16 PM
IM QUIKR's Avatar
IM QUIKR
So why? Was it a bad coil, wire or plug?
