You will be able to see the 9/32 screws that secure the light in place....you only need to remove the one closest to the outside of the car as the other 2 hold the fixture to the plastic mount which you will see when it is removed...next you need to push the brake cooling duct down and out of your way so you can reach the 10mm screw securing the front part of the light...this is a beotch and also where the ratchet with swivel comes in handy. After the screws are out there is a small reatining spring holding the fixture in place..carefully remove it from the light and leave the other end hooked up.....yeah I know..you dropped it its easy to reinstal and it slides into a notch in the back of the black mount for the light....its pretty self explanatory.
Now you have this
take the remaining 9/32 screws out and remove the black mount from the light fixture
Ok...wasn't that fun??? Now the real fun begins putting it back in
before you do anything else put your new bulbs in the socket.
Carefully slide the new fixture up into place and reinstal the bulbs and re-attach the spring...(dropped it again didn't ya )
Now slide the fixture in place and this is where it gets fun...reach up and move the brake duct out of your way enough to jam your hand (which doesn't fit) into the opening and get the 10mm screw started on the front part of the new light. Now move around front and tighten with the 10mm socket using the ratchet with swivel attached....this is where patience and beer comes in handy Now reinstall the 9/32 screw on the other end. Check to make sure the lights work before re-installing the closeout panel and spoiler. You are all set.
Now....do the other side.
Pics of finished work. I had the turn signal on to show different levels of brightness.
BUT, I cant give up the bright orange parking lights while crusing during sunset. Thats CORVETTE right there!
You don't give up those bright orange daytime running lights at all....
It actually makes them brighter.........but you hardly see them from the side.
Check out my pics and you'll see what I'm talking about.
here from the front you can tell they are brighter and clearer.
here they are on, but you can't hardly tell from the side, due to how the chrome reflects it.
