Help - Won't Start (not battery)
Old Dec 15, 2005 | 06:39 PM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default Help - Won't Start (not battery)
Well, I went out to the car today and it wouldn't start. It has had this 'electrical glitch' non-starting issue intermittently (about 3 times) ever since I loaned it out one evening about a month ago (I trust the guy, so I don't assume foul play). The issue started with the symptoms listed below, but always eventually started after a few tries, and 90% of the time there was no issue at all. Tonight it would not start after dozens of tries.
Symptoms:
- no spark, nor does the starter turn over.
- all electrical seems to turn on fine, the battery is okay, and putting a portable jumper unit on it doesn't help.
- no current codes
- holding the ingition to "start" and letting the clutch in/out causes the relay? in the pass footwell to switch, so I'm pretty certain it has nothing to do with the switch under the clutch pedal.
Old Dec 15, 2005 | 08:27 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
This is a big clue, and rules out a lot of possibilities.
The relay in the pass footwell you hear clicking is called the theft deterrant relay. This relay (when energized) is what sends 12v to the starter solenoid. It is located right next to the BCM (the silver colored box in the pass. footwell).
The fact you hear it clicking (relay pulling in), not only indicates the clutch pedal switch is working, it also rules out a bad key/ignition switch issue, as the BCM supplies the ground signal to the coil of that relay. If it were a key problem, the BCM wouldn't supply ground to the relay coil, and the relay wouldn't pull in even when power from the clutch switch was applied.
Doubtful, but you could first check the 60a fuse labeled "starter" in the footwell fusebox. If this is good, the next step would be to check the wires at the theft-deterrant relay. It can be identified by the 4 wire colors...red, purple, yellow, yellow/black stripe. The yellow wires are the coil wires, we know they are doing ok if the relay is pulling in when trying to start.
The red wire should +12v at all times. Verify this first.
If that has 12v, the next step would be to have someone depress the clutch, and turn the key to start. Relay will click. Now check the purple wire, at this point it should have +12v. This purple wire runs directly to the starter solenoid. If you have 12v there during an attempted start, and still no response, almost definitely your starter is bad. The only other possibility would be a bad connection or broken/burnt wire at the starter terminals.
I had this happen to me earlier this year, same symptoms. I replaced the starter, and all has been well since.
Old Dec 15, 2005 | 08:34 PM
DngrZne's Avatar
DngrZne
Bad ground somewhere perhaps?
Old Dec 15, 2005 | 08:36 PM
VA 98 VETTE's Avatar
VA 98 VETTE
Sounds like a starter solenoid going bad.
Old Dec 15, 2005 | 08:47 PM
BQuicksilver
Great replies, thanks guys (esp y2kvert4me...I think that pretty much lines out what I need to do).
I'll report back.
Old Dec 16, 2005 | 02:30 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WOW!! EXCELLENT write up!! Couldnt have said it better myself!
BC
Old Dec 16, 2005 | 03:42 AM
markcz's Avatar
markcz
Check to make sure the battery terminal bolts are both snug (especially the red one). I've seen cars not start because the terminals just didn't have enough contact with the battery to pass the required amps that the starter needs, but everything else on the car works just fine
Good luck, let us know what you find
Old Mar 13, 2013 | 10:28 PM
Patrickdfwfo's Avatar
Patrickdfwfo
2nd Gear
hi guys, i have the same problem it has done it the 2.5 years i have owned it, but has always started after holding the key to start for 10-45 sec. do you think it is still the starter, just seems like it would have completely failed by now. thanks
Old Mar 13, 2013 | 10:43 PM
johnodrake's Avatar
johnodrake
Moderator
http://forums.corvetteforum.com/foru...s-or-more.html
Please don't revive old threads.
To Help - Won't Start (not battery)
