LS2 TB.. how did you mount?
Old Dec 17, 2005 | 10:16 PM
usnskeet21's Avatar
usnskeet21
Default LS2 TB.. how did you mount?
I installed my LS2 TB today. I started with the motor part on the drivers side, like the LS1 was.... Problem ( as usual) the LS2 wont clear the powersteering pump resevoir. SO i turned it to the passenger side, fits fine. Now my question to everyone is.. the LS1 throttle blade pushed IN at the top. and not the LS2 pushes in at the bottom. Will this make any differences? Anyone wil the 90mm TB chime in.
Old Dec 17, 2005 | 10:18 PM
WKMCD's Avatar
WKMCD
That's how mine is.
Old Dec 18, 2005 | 01:00 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
It sounds normal. The LS2 tb in my 402 stroker is mounted the same way you describe. In fact, if you look under the hood of a C6, the motor is also oriented toward the passenger side.
Old Dec 18, 2005 | 04:56 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Originally Posted by WKMCD
That's how mine is.
Old Dec 19, 2005 | 09:12 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Tryin to catch me eh...............
Old Dec 19, 2005 | 09:39 AM
JoeyG's Avatar
JoeyG
Nah, said screw it, gonna do the hot rod drag week this year. Up for a co-car spot?
Old Dec 19, 2005 | 10:23 AM
Cruise-In V Veteran
NCM Ambassador
I should have specified I ment my knucklehead nephew above
Coming to SC in Feb with the silver flash?
Old Dec 19, 2005 | 11:15 AM
JoeyG's Avatar
JoeyG
If work and college will allow it
Old Dec 19, 2005 | 04:53 PM
usnskeet21's Avatar
usnskeet21
Well i got it all on and wired, my computer is SOOO confused and is gonna have to stay like that for 9 more days (poor guy) looks good we will see about power next week. Last thing left is the catch can especially after seeing how much oil was in my intake when i pulled it off.
Old Dec 19, 2005 | 05:05 PM
JoeyG's Avatar
JoeyG
Catch can's work wonders Fast 90 intake or ls2?
Old Dec 19, 2005 | 06:32 PM
usnskeet21's Avatar
usnskeet21
Same setup as yours Fast 90 w/ LS2 TB... where did you get your catch can?
Old Dec 19, 2005 | 09:07 PM
JoeyG's Avatar
JoeyG
It's a greddy can with my own mount. I use the Metco breather on the pass side valve cover, block both pcv ports on pass cover. Then have the driver side valve cover gromment connected to the catch can with 1/2" hose. The catch can the goes through a factory replacement pcv valve to the fast port.
I didn't want to drill the air duct for the fresh air hose like most do. Plus the Metco breather is so much nicer looking and uncluttered, so to speak. How did you luck out and have Steve for an uncle?
Old Dec 21, 2005 | 07:15 AM
Cruise-In V Veteran
NCM Ambassador
Hum..........can't wait for THAT answer
Old Dec 21, 2005 | 08:40 AM
JoeyG's Avatar
JoeyG
antaganist
Old Dec 21, 2005 | 10:41 AM
usnskeet21's Avatar
usnskeet21
that one will have to be taken up with the pops and grandparents..
so where did you get the catch if you can remember ??
To LS2 TB.. how did you mount?
