Front pad shims
Old Dec 19, 2005 | 11:00 PM
zr1-2go's Avatar
zr1-2go
Default Front pad shims
Anyone know the do's and dont's about the front pad shims. I'm running Hawk pads. Missing one of the end shims.
Old Dec 20, 2005 | 02:08 PM
CHJ In Virginia's Avatar
CHJ In Virginia
The shim kits are designed to keep the pads in good alignment and to reduce noise. The end shims that fit on the caliper bridge (2 similar shims) keep the pads from bouncing back and forth. The long one with 4 forks keeps the pads pushed down and in full contact with the rotor. My Z came with one of the end shims missing from the factory. If the car is quiet don't worry about a missing end shim. If it rattles or squeals badly, get a set from the dealer. I always replace all my shims when changing pads.
