How much for a rear main seal replacement?
Old Dec 21, 2005 | 09:30 AM
ztron's Avatar
ztron
Default How much for a rear main seal replacement?
I may have to have a rear main seal replaced anybody had this done, and if so how much are we talking about? Thanks
Old Dec 21, 2005 | 09:37 AM
Phil97SVT's Avatar
Phil97SVT
You've got to remove the drivetrain just like a clutch swap, usually 600-1000.
Phil
Old Dec 21, 2005 | 09:38 AM
EHS's Avatar
EHS
I had it done twice under warranty.
The parts cost are minimal, but the labor is at least a day.
8 x your labor cost, plus $75 in parts.
Old Dec 21, 2005 | 10:51 AM
ztron's Avatar
ztron
I just got a est. for the rear main seal, the stealership was $500-600.00. is this something a local general mechanic can do as to save some money, or would you guys feel more comfortable with a GM service guy,,,, any comments.. I just dont feel comfortable with just any one working on it,,, I do have one guy that is a pretty good mech...
Old Dec 21, 2005 | 01:47 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Well I got mine replaced under warranty after seeing black spots on the floor. I had the Corvette-only tech at the dealership do it and all is well. He said in all his years he hadn't seen the rear main go out on a C5. But... I had a new clutch in that was off balance and might have caused the issue.
The trickey part is dropping nad removing the whole torque tube, transaxel and rear subframe.
If a mechanic doesn't know what he is doing he can really mess stuff up... it a very unique design.
FWIW $500 doesn't sound bad.
Old Dec 21, 2005 | 07:00 PM
LoneStarFRC's Avatar
LoneStarFRC
Also be sure your not seeing the results of a leaking oil pressure sending unit. If it's the sender it will usually mean the oil will stay on the outside of the bellhousing and come down the side(s). If it truly is a rear main, the oil will be much more prevelant inside the inspection cover and/or bellhousing. HTH
Old Dec 21, 2005 | 09:04 PM
Dave1's Avatar
Dave1
St. Jude Donor '09
...Good tip...
If your not sure what is leaking, spray it all down and get it dry and clean. Then run it again and check again for signs of leaking.....Good luck....
Old Dec 21, 2005 | 09:25 PM
EHS's Avatar
EHS
It's a big job -- the entire rear of the car gets taken out.
$500 from someone who knows what they're doing (if they do), isn't bad.
Old Dec 22, 2005 | 10:17 AM
ztron's Avatar
ztron
I do have a sending unit problem its pegged at 80+psi,,, anyone think that this could be a issue with the oil spots...
Old Dec 22, 2005 | 05:21 PM
LoneStarFRC
Sounds like you have just located the source of the leak. When my original sender went belly-up, I found some oil seeping from it too. It had partially run down the back side of the bell housing but hadn't quite made it to the ground yet. The intake manifold has to be removed (or at least unbolted and moved forward) in order to get to it.
I would recommend that you not replace it with another Delco as I have seen too many posts here from guys who did, only to find that the replacement Delco also went bad a short time later. I went with a PS-308 made by Standard Motor Products. That brand has been around for a long time and is available from a number of parts stores. It's been on for almost two years now and is working just fine. I got mine on-line from RockAuto.com. Another trustworthy brand is Borg-Warner. HTH
To How much for a rear main seal replacement?
