What is the zip tie mod?
Stock Box assembly
Other than a slightly bigger opening, the box portion is the same. So, you don't need to buy a new Z06 intake. Any C5 intake will work just fine.
I used the factory clamps. I simply removed the factory metal straps and replaced them with shorter one made from wire ties. This allows for consistent pressure to the filter frame.
Here Mc Rat's car. They just wrapped the ties around the box. I re-used the factory hardware to allow you to change the filter.
Hope this helps...
Don't do it, $50,000 car with a 10 cent mod stopping dirt and water
But it is your car, and is it worth the 2 HP
I did the zip tie mod W/ K&N and yes it was worth it, but if I did it again I would just cut a big a$$ hole in the middle of the oem cover. I would feel better about it sealing but I've put on 30K mi+ on it with the zip ties and the mass air flow meter is still clean so it must be sealing. I spent the $300 I saved from buying a intake on a cam instead
HP
TQ
When done properly as stated it will clamp as good or better than the stock metal clamps.
People look down on the Zip tie mod as it is cheap. Then they spend $600 on an intake that seals poorly, and has abismal filtration, and then get on the forum and sing its praises.
Look, no one is hold a gun to anyones head. If you want to use an aftermarket intake, please do. Thats what great. Its your car, and you can do whatever you want to it. Thats one of the things that is great about this country. Well have choices.
Anyway, IMHO and again, its only my opnion. I think the zip tie mod is the best bang for the buck. You may or may not agree, YMMV.
You may want to chop the front out of the stock lid. You may want to do the zip tie mod. On the other hand you may want to buyan aftermarket intake. The choice is entirely up to you.
Whatever choice anyone makes, just be happy with it, and go enjoy your car...
Merry Christmas everyone...
One question, is the Z06 air bridge the same as the stock C5? Assuming that's the same, it looks like the filter and airbox lid are the largest restrictions in the whole setup.
HP
TQ
any tuning?
I am a bit concerned about inhaling water. I used a 3/4" drill bit and neatly added a total of six holes through the cover then used the stock straps etc.
RonJ ...
I am a bit concerned about inhaling water...
One is meant to be exposed, the other not.
I did this,later went with the hype and put a Halltech on, car was quicker with this, by a fraction
