Just exploded my pressure plate.
Old Dec 23, 2005 | 06:58 AM
Dark-Knight's Avatar
Dark-Knight
Man, glad you're OK. You could have been seriously hurt, think the speed served you well.
Old Dec 23, 2005 | 08:31 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Damn, thats a very bad sequence of events. Hope everything works out for you, just keep a positive perspective
Old Dec 23, 2005 | 08:53 AM
HP_Addict's Avatar
HP_Addict
At least it did not take your legs off. I am surprised this does not happen more often. Maybe it does and people just do not post about it. So whats the solution to containing a PP explosion?
Old Dec 23, 2005 | 10:02 AM
AnteVenom's Avatar
AnteVenom
Daytona Jam 1 Veteran
So Sorry to hear of this. I too had this happen although for other reasons but the damage you describe is nearly the same as I experienced. Even the pieces of bell housing coming through the firewall is the same.
Good news is you are okay and the car can be repaired.
For those interested in something to contain this type of explosion. There is nothing available that i know of and I did a good bit of research after my experience in 2002. The only workable solution is to have a steel bell housing custom made at great expense and additional weight to the car.
Good luck with this and hopefully it will not completely dampen your holiday celebrations.
Old Dec 23, 2005 | 11:09 AM
Smoove
Guest
Posts: n/a
Crazy experience right....
I've taken alot of the stuff off the car...it can be repaiered but,...it's gonna cost me. Headers/bellhousing/clutch assembly/flywheel/A/C line(all of them)hydraulic clutch lines/firewall damage in several areas/wireing harness(s)wiper assembly,arms/engine block has crack.
...but,..tomorrow i'm going on a long awaited cruise so,...gonna get a little crazy for a week.
Old Dec 23, 2005 | 12:47 PM
JoeyG's Avatar
JoeyG
mas tequilla por favor
Old Dec 23, 2005 | 02:27 PM
Smoove
Guest
Posts: n/a
grassy ***.
Matter of fact,..I think i'll start tonight.
You all have a great weekend,...take care.
Old Dec 23, 2005 | 02:56 PM
edensknight's Avatar
edensknight
Originally Posted by gonbad
One of my biggest fears with this car. High HP configurations and no way to add a armored bell housing and a no one I know of makes a blanket that will fit.
I had a 72 BB 454 Vette back in the 80's blow up a Centerforce clutch like that. One big piece stuck in the pavement under the car. Could have taken one of my legs off.
This has been known to happen and the assembly going through the dash and cowl and taking out the windshield seems to be the common exit point.
Old Dec 23, 2005 | 05:45 PM
zulatr's Avatar
zulatr
pictures????????????????????????????????
Old Dec 27, 2005 | 08:23 AM
Blue Lightening's Avatar
Blue Lightening
Old Dec 27, 2005 | 10:26 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Glad you are ok this could of gone bad.
I lost a high school friend at the race track from this happening in a mercury cyclone. Second time at track with car flywheel shattered at about the 20ft line. He lost both feet in seconds and later died at hospital from his injures.
Good luck
B
Old Dec 27, 2005 | 10:30 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Now for my idea with insurance.
It was under their direction that you took it for a spin. A soaked clutch disk could of done this or derbies in the clutch pack. The damage due to flood is completely feasible. Ride them hard they will fold when they come to realize they instructed you to take car for a ride and endangered your life.
Good Luck
B
Old Jan 3, 2006 | 04:22 PM
  #33
Smoove
Guest
Posts: n/a
Good Luck
B
Thanks...i'm still pushing them.
As for the pictures,..I have plenty of them. Thanks for your patience...I will post them but, not before I have an answer from my insurance company. When they tell me, yes they're gonna fix it, i'll post the picture right after.
J
Old Jan 3, 2006 | 04:39 PM
  #34
Phil97SVT's Avatar
Phil97SVT
So did....
1) The flywheel come apart
or
2) Clutch material came off the disc
or
3) Pressure Plate come apart
Glad your OK!
Phil
Old Jan 3, 2006 | 06:46 PM
  #35
Smoove
Guest
Posts: n/a
Originally Posted by Phil97SVT
So did....
or
or
Glad your OK!
Phil
Car is off the lift now...but, from what you could see, without removeing anything from the car but loose debree, was that the pressure plate came apart. Clutch looks intact, flywheel looks intact. Again, this is looking at everything from underneath the car.
Old Jan 3, 2006 | 07:23 PM
  #36
devil427's Avatar
devil427
YOU'RE OK !!! THE MOST IMPORTANT !!!
I'm not sure that water was the cause ...
We recently bought a new stage 2 Spec clutch , but we've never installed it .....! the pressure plate came with oval bolts holes !!! and the centering pins holes were too large for the flywheel pins !!! It was impossible to BALANCE it .
JO.
Old Jan 13, 2006 | 07:24 PM
  #37
pat03z06's Avatar
pat03z06
Which Spec is this ? I just had a Spec 3.
How muw power are you putting down and were you on street tires?
My feet need to know.
To Just exploded my pressure plate.
Old Jan 26, 2006 | 05:52 PM
  #38
Smoove
Guest
Posts: n/a
stage III....good luck
Power level at the time,..between 4 and 5 hundred horse,...much more on spray.
wasn't spraying at the time.
here is a couple of pics.
http://www.ls7power.com/images/FRC/142_sm.jpg
http://www.ls7power.com/images/FRC/137_sm.jpg
I have alot more but, am waiting for the final say on my insurance before i post more.
Sorry for the delay.
Old Jan 26, 2006 | 05:56 PM
  #39
vetterlatethannever's Avatar
vetterlatethannever
Glad you are alright!!
Old Jan 26, 2006 | 06:41 PM
  #40
turboc5's Avatar
turboc5
Let us know how it turns out. Glad you still have your feet
