Calling the Tech Pro's
Old Dec 22, 2005 | 08:00 PM
webdzynes's Avatar
webdzynes
Default Calling the Tech Pro's
Are the dampers that control which vent the AC and heat flow through controlled by a fuse and if so, which one? All air (heat or A/C) is only coming thru the Defrost vent and nothing seems to change that. Is it a suction tube? I disconnected the battery for a bit hoping to reset it, but no luck. (I'd even do it manually if i could for now) ....
Old Dec 22, 2005 | 08:14 PM
dpd's Avatar
dpd
check the vacuum line under the battery tray that comes from the intake manifold.the ducts are controlled by vacuum while the blend doors are stepper motors.
Old Dec 22, 2005 | 08:30 PM
webdzynes's Avatar
webdzynes
i'm not real sure what I'm looking for but all hoses look to be connected. dont see anything abnormal...
Old Dec 22, 2005 | 08:36 PM
dpd's Avatar
dpd
have you checked for faults?have you experienced the leaky battery syndrome?
Old Dec 22, 2005 | 08:55 PM
webdzynes's Avatar
webdzynes
No apparent problem there. I replaced the battery with a Yellow-top a long time ago...
Old Dec 22, 2005 | 10:14 PM
webdzynes's Avatar
webdzynes
ttt
Old Dec 22, 2005 | 11:13 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ahhh, been here fixed this!! When my 98 was just out of warranty, this happened to me! Here is what causes it!
On back of the intake manifold there is a fitting. It houses the MAP sensor and supplies vacuum to the brake booster and vacuum to the HVAC system. Without vacuum the HVAC dampers fail in the defrost mode to allow you to see.
Here is a pic of the fitting:
Here is a picture of the rubber connection that fits on that manifold fitting.
Here is a picture of the vacuum resivour that is located in the passengers fender well. The lines connect to the bottom of the black plastic can.
Bill C
Old Dec 22, 2005 | 11:58 PM
webdzynes's Avatar
webdzynes
Bill C
Bill!! You are a GENIUS!!! You were absolutely spot on! Its a bear to get to without pulling things apart but the hose was indeed unhooked. I managed to get it back in and all works perfectly. THANK YOU SOO MUCH for taking the time to help me out. If you were around here, I'd buy you a case of whatever you like! THANKS AGAIN!!
To Calling the Tech Pro's
