First oil change?
Old Aug 3, 2001 | 12:44 AM
Sean2001's Avatar
Sean2001
Default First oil change?
WHen should you first change your oil..I have 1500 miles on my 2001 couple..I also live in a new development with lots of dust and construction. not to mention the south florida heat..I was going to changethe oil this weekend..is it worth it? or a waste of time :confused:
[Modified by Sean2001, 11:44 PM 8/2/2001]
Old Aug 3, 2001 | 12:52 AM
Ken King's Avatar
0Ken King
Former Vendor
CF Pit Crew
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05
Default Re: First oil change? (Sean2001)
Hi Sean
I make my first change at 500 miles, I want to let the car run enough to clean out the manufacturing crap but not so long that it runs through the engine to many times. I also put in a magnetic drain plug.
Ken
Old Aug 3, 2001 | 01:20 AM
barryscott's Avatar
barryscott
He Now:
I changed first time around 800 then every 3,000. :yesnod:
Old Aug 3, 2001 | 01:25 AM
BruceF's Avatar
BruceF
Default Re: First oil change? (barryscott)
Time for a change
Old Aug 3, 2001 | 01:32 AM
Sean2001's Avatar
Sean2001
Default Re: First oil change? (BruceF)
:seeya thnaks for the reply..all..I purchased an ultraguard filter and a magnetic drain plug..Saturday it is..thanks :cheers:
Old Aug 3, 2001 | 01:33 AM
Sean2001's Avatar
Sean2001
:seeya thanks for the reply..all..I purchased an ultraguard filter and a magnetic drain plug..Saturday it is..thanks :cheers:
Old Aug 3, 2001 | 02:17 AM
sandyg's Avatar
sandyg
First oil change was at 750 miles. I then changed oil, filter and added a magnetic drain plug. Thereafter I change oil every 1000 to 1500 miles or every 2-3 months.
To First oil change?
