Which Plug is best? Need Advice
The time has come to replace those 100,000 mile stock plugs and was wondering what other vette users out there use. Two options i am considering is the stock 100k mile ac delco ones or the NGK DENSO IRIDIUM, i've heard they perform really well and last very long but kinda of expensive. Let me know what you think.
Ralph
I bought mine from Pep Boys here in California, but if you can't find it nearby you can by it here:
http://www.autopartsgiant.com/welcom...ds&kwd=NGK.gif
This is to advise ALL Corvette c5 owners of a bulletin, 03-06-04-060, which updates spark plug application and gap.
This states that as of 24 October 2003, part number 12571164 is the replacement spark plug for ALL c5 Corvette, LS1 and LS6.
However, this also shows us that the new gap, of .040, is set at the factory. Any attempt to regap this plug could damage the plug. We are instructed to NOT USE THE PLUG, if the gap of .040 is not there. DO NOT GAP TO .060.
NOW, the largest point to be made here, is that this plug uses an Iridium tip for the electrodes.
This is the first for Corvette.
Others claim to be Iridium tipped, but are NOT in the GM line.
The ACDelco number is 41-985.
So, with that, please be aware of this and utilize this plug from here on in.
Aside from this, I have contacted GM powertrain on the updating to the PCM control calibration for these new plugs and have been told that the latest calibrations are already set up for the revised plugs. Apparently, they knew these plugs were coming, and compensated accordingly
So does that mean in order to use the new plug in a vehicle manufactured prior to the 2003 date we need to have the PCM reprogrammed?
Gm says 100k tune, not in the real world might still running but not good.Plugs are toast at 70k
Fancy plugs don't last like they claim and if you regap to .060 it's going to run better.
From what I have heard there is too great a chance of damage to the plug if you try to change the gap.
Advance and Napa carry the ngk's in new england
as long as you didn't crack the insulator or any thing like that........ you should be good to go.
Car works great and I've had no issues.
