99 Key Fob Help
Old Dec 25, 2005 | 04:27 PM
jcrane5085's Avatar
jcrane5085
7th Gear
Default 99 Key Fob Help
My fobs cease to work or they make the audible alarm beep everytime I go thru the steps of programming my fob. If they are programmed in the passive mode, the alarm beeps every 3 minutes(regardlees how far the fob is from the car). If they are programmed in the passive off, they work for a day. I just bought this car and I am new to the Corvette forum, so please forgive my ignorance and possibly protocol. Merry Christmas to everyone, JC
Old Dec 25, 2005 | 05:14 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
JC
Replace the battery in them and reprogram and see if that works.
If not and those are the original remotes you probably will need to
replace them. I would replace one at first and if that solves your problem then you know the second one needs to go also.
PS. Merry Christmas and congrats on your recent purchase.
Old Dec 25, 2005 | 07:42 PM
jcrane5085's Avatar
jcrane5085
7th Gear
RnR, thanks for the reply, I should have went into more detail, but I failed as usual. Ive replaced batteries in both units (only one unit came with the car so I bought a second one on Ebay). Im open for any and all suggestions, Merry Christmas, JC
Old Dec 25, 2005 | 08:42 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Are your tire pressure sensors giving you readouts? If so then your receiver is OK as they both operate on the same frequency.
Buying a used one is always risky. Usually what solves the problem 99.9% of the time is a new one.
Part # 10253839
Old Dec 25, 2005 | 10:58 PM
99bronzecoupe's Avatar
99bronzecoupe
Part # 10253839
Mine couldn't hold the program for a more than day. Got a new one and now it seems to be holding.
To 99 Key Fob Help
