LQ9 6.0 heads
Old Dec 26, 2005 | 12:07 PM
frc's Avatar
frc
Default LQ9 6.0 heads
I'm fixing to put a supercharger from A&A on my 99 frc 24,000 miles. I'm looking to put a set of heads and intake on my car as well. What do you think on the LQ9 6.0 heads? Thanks
Old Dec 26, 2005 | 01:28 PM
frc's Avatar
frc
ttt
Old Dec 26, 2005 | 01:51 PM
mdhmi's Avatar
mdhmi
I like the 72cc 6L heads for FI cars (lowers the CR). An LS6 intake is fine for your setup.
Mark
Old Dec 26, 2005 | 02:03 PM
FreddyG's Avatar
FreddyG
Mark
...........and have the same free flowing ports as the LS6 heads. That should be a Nice Setup!
Old Dec 26, 2005 | 03:05 PM
frc's Avatar
frc
What do I need to do to the heads? I've never done anything but bolt ons and i'm looking for a nice setup that is streetable. I've got these heads(6.0 LQ9) and LS6 intake in my garage and fixing to order a kit from A&A. What cam if any? Thanks for all input.
Old Dec 26, 2005 | 03:38 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
You may as well definitely go with a blower cam and the one Andy is using at A&A with huge success has specs of 224/228 .581/.588 114 LSA.
With this cam you will need a good valve spring and titanium retainers on the heads and the don't skimp with the valve springs and best on the marekt on the comp 921 dual springs which do not require any machining with the stock LS9 heads or LS6 heads, etc. Also, the patriot gold duap springs are a great option also for a few less $ and get a dual spring for the added protection of having the second spring keeping the valve from dropping if the first spring breaks, etc.!!!
Old Dec 26, 2005 | 03:44 PM
mdhmi's Avatar
mdhmi
Mark
Old Dec 26, 2005 | 06:41 PM
frc's Avatar
frc
What rockers and push rods should i use? Thanks for all info so far!
Old Dec 26, 2005 | 08:08 PM
vettenuts's Avatar
vettenuts
Might also want to consider ARP studs instead of the stock bolts for the head installation.
Old Dec 27, 2005 | 12:27 AM
edensknight's Avatar
edensknight
To LQ9 6.0 heads
