led lights
Old Dec 26, 2005 | 01:55 PM
boss31's Avatar
boss31
Default led lights
I just got led tail lights for christmas they look great but they blink faster then the factory ones. Are they suppose to blink faster then the factory ones?
Old Dec 26, 2005 | 01:59 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
From what I understand the flasher thinks the bulb is out.
Try this, unplug the new LEDs, the dash flasher should flash the same as if you added the LEDs.
Ever have a bulb go out? Thats how you know one is out.
Old Dec 26, 2005 | 08:00 PM
boss31's Avatar
boss31
Default led lights
I did what you said . So what your saying is that the led lights flashing fast is normal
Old Dec 26, 2005 | 10:34 PM
Dixit's Avatar
Dixit
http://www.superbrightleds.com/cgi-b...gi?product=CAR
You need the load resistor on that website. It will simulate a load of regular filament bulb so the flasher returns to normal speed.
Dixit
Old Dec 27, 2005 | 10:21 AM
screw991le's Avatar
screw991le
It is normal for the car to react that way, like said above you need to adjust the blinker with the resistor.
Old Dec 27, 2005 | 12:59 PM
skidmarc's Avatar
skidmarc
Has anyone installed the LEDs with the Euro tail lights? Is the bulb replacement form fit and fuction or do you need new harness? Any pictures?
To led lights
