0 psi oil. Ideas.
Old Dec 26, 2005 | 04:45 PM
usnskeet21's Avatar
usnskeet21
Default 0 psi oil. Ideas.
Im getting an oil pressure sensor tomorow. Besides that and the relief on the oil pump sticking open. What else has anyone heard of on an LS1 causing this? Its a 99 with 83K. Im not gonna sleep at all tonight.
Old Dec 26, 2005 | 04:51 PM
dpd's Avatar
dpd
if the relief valve is hung open,you will have 0 oil pressure.usually with our cars if the switch goes bad,you have a high reading.are you sure the pump itself didn't puke?
Old Dec 26, 2005 | 05:02 PM
usnskeet21's Avatar
usnskeet21
i have 0 oil pressure. I dont know thats why i am starting with the sensor and getting ideas for other problems.
Old Dec 26, 2005 | 05:09 PM
dpd's Avatar
dpd
is the motor noisey? tapping,knocking,etc.? if the oil pressure switch is disconnected you will have 0.spin off the oil filter,if it's empty,you have a flow problem.
Old Dec 26, 2005 | 06:45 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Guess you made it home ok
Old Dec 26, 2005 | 08:52 PM
usnskeet21's Avatar
usnskeet21
made it home and got the car apart but no sensor... gm place was closed. so gotta wait tomorow.
To 0 psi oil. Ideas.
