rotors
Old Dec 26, 2005 | 08:29 PM
DBL001's Avatar
DBL001
Default rotors
I e-mailed T-Byrne about rotors but want opinions from you guys, I want to upgrade my wheels to CCW 505 a's 19" rear and 18" front, I want to order sl/cd rotors, I think it looks better in the rear to go with 14" rotors but what about the caliper, should I go with a bigger caliper? And if so how much are they and from where? Any help would be appreciated...I'm confused (naturally)lol
Old Dec 26, 2005 | 08:55 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
You need to match the caliper piston size to your stock rear caliper or your bias will be ruined. Larger caliper will require bigger master cylinder or you will have a soft pedal at the minimum. Big break kit will have this fron Wilwood or Stoptech but it is not cheap call
lgm if you want to go that route.
Old Dec 26, 2005 | 10:19 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
505's with 14 inch rear rotors, 13 inch front rotors...absolutly no problems with stock calipers. Baer 2 piece Eradispeeds.
To rotors
