pulliung the A/C compressor??
Old Dec 27, 2005 | 02:01 PM
idiedtrying's Avatar
idiedtrying
Default pulliung the A/C compressor??
I Have The Blet Off And All The Lines, But Now Im Stuck, I Cant Get It Out... It Wont Go Underneath Either... Any Ideas...??
Old Dec 28, 2005 | 05:50 PM
idiedtrying
well i kept reading my manual, so i finally got it.. to let anyone know if interested, you have to remove the water pump to pull it out...
not bad at all
Old Dec 29, 2005 | 12:14 AM
rws.1's Avatar
rws.1
3 ways... you choose
1. remove water pump
or
2. Remove rad
or
3. Remove exhaust manifold
Old Dec 29, 2005 | 09:38 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Document ID# 576962
2000 Chevrolet/Geo Corvette
Compressor Replacement
Removal Procedure
Recover the refrigerant. Refer to Refrigerant Recovery and Recharging .
Remove the battery heat shield. Refer to Battery Heat Shield Replacement in Body Front End.
Remove the accessory and compressor drive belts. Refer to Drive Belt Replacement - Accessory and Drive Belt Replacement - Air Conditioning in Engine Mechanical.
Remove the water pump. Refer to Water Pump Replacement in Engine Cooling.
Disconnect the compressor clutch electrical connector.
Remove the compressor hose to compressor retaining bolt.
Important
Cap or tape the open compressor hose immediately to prevent contamination.
Disconnect the compressor hose from the compressor, discard the seal washers and cap or tape the hose end to prevent contamination.
Remove the compressor mounting nut.
Fully loosen the compressor mounting stud.
Remove the compressor mounting bolts.
Remove the compressor and the mounting stud from the vehicle.
Remove the compressor mounting stud from the compressor.
If replacing the compressor, drain and measure as much of the oil as possible from the removed compressor:
Drain the oil from both the suction and discharge ports of the removed compressor into a clean container.
Remove the compressor crankcase oil drain bolt (1) and drain the crankcase oil from the removed compressor into the same container.
Measure and record the amount of oil drained from the removed compressor. This measurement will be used during installation of the replacement compressor.
Installation Procedure
Replacement compressor will come without refrigerant oil. When adding oil to this compressor, adhere closely to the following instructions:
If the amount of oil drained from the old compressor is less than or equal to 60 ml (2 oz), add 60 ml of new clean oil to the new compressor.
If the amount of oil drained from the old compressor is greater than 60 ml (2 oz), add the same amount of new clean oil to the new compressor as drained from the old compressor.
Install the compressor mounting stud to the compressor.
Install the compressor into position on the compressor mounting bracket.
Install the compressor mounting stud to the engine block.
Install the compressor mounting bolt in the upper, forward position (net locating hole).
Install the remaining compressor mounting bolts.
Tighten the compressor mounting bolts in the following sequence:
Front upper, first
Front lower, second
Rear lower, third Tighten
Tighten the compressor mounting bolts in sequence to 40 N·m (30 lb ft).
Tighten the compressor mounting stud. Tighten
Tighten the compressor mounting stud to 9 N·m (80 lb in).
Install the compressor mounting nut. Tighten
Tighten the compressor mounting nut to 40 N·m (30 lb ft).
Remove the cap or tape from the compressor hose end (2).
Using a lint-free clean, dry cloth, carefully clean the sealing surfaces of the compressor hose (2) and the compressor (3).
Lightly coat the new seal washers (1) with mineral base 525 viscosity refrigerant oil.
Important
DO NOT allow any of the mineral base 525 viscosity refrigerant oil on the seal washers to enter the refrigerant system.
Carefully slide the new seal washers (1) onto the compressor hose (2) until seated.
Install the compressor hose to the compressor.
Install the compressor hose to compressor retaining bolt.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Important
After tightening the compressor hose (3) to the compressor (2), there should be a slight sealing washer gap (1) of approximately 1.2 mm (3/64 in) between the compressor hose (3) and the compressor (2).
Tighten the compressor hose to compressor retaining bolt. Tighten
Tighten the compressor hose to compressor retaining bolt to 26 N·m (19 lb ft).
Connect the compressor clutch electrical connector.
Install the water pump. Refer to Water Pump Replacement in Engine Cooling.
Install the accessory and compressor drive belts. Refer to Drive Belt Replacement - Accessory and Drive Belt Replacement - Air Conditioning in Engine Mechanical.
Install the battery heat shield. Refer to Battery Heat Shield Replacement in Body Front End.
Refill the cooling system. Refer to Draining and Filling Cooling System in Engine Cooling.
Evacuate and charge the refrigerant system. Refer to Refrigerant Recovery and Recharging .
Check the compressor hose to compressor joint and the compressor for leaks. Refer to Leak Testing .
Old Dec 30, 2005 | 07:40 PM
idiedtrying
got it, everything turned out good.. thnks everybody
To pulliung the A/C compressor??
