Underhood Questions
Old Dec 27, 2005 | 04:33 PM
sowega's Avatar
sowega
Default Underhood Questions
I was poking around under the hood and trying to get motivated to clean the ground points, when I found this. Any thing seem out of the ordinary?
I pulled the folded hose out of the and found the other hose that it seems that it should connect to:
What are these hoses, and should they be connected?
Old Dec 27, 2005 | 05:20 PM
runman's Avatar
runman
Hose comes from the AIR pump, should be connected
Old Dec 27, 2005 | 05:22 PM
LoneStarFRC's Avatar
LoneStarFRC
Surprising your not getting some codes. The hoses are part of the A.I.R. system (emissions control) and send fresh air to your electrically operated A.I.R. pump which in turn sends fresh air to your exhaust manifolds (through two check valves). This system is active during open loop and shuts off after your engine warms up goes into closed loop operation. Has someone else owned the car before you or have you had someone else working on it before?
Old Dec 27, 2005 | 05:23 PM
sowega's Avatar
sowega
Do you have any idea why anyone would disconnect them?
Old Dec 27, 2005 | 05:25 PM
LoneStarFRC
If someone has set your car up for "track only" type operation maybe. You may wind up having a state inspection problem come time for renewal.
Old Dec 27, 2005 | 05:26 PM
sowega's Avatar
sowega
My dad bought the car about a year and a half ago, and, after a too many (in his mind) issues, he wants me to buy it so he can get a C6. I don't know who's been working on it, but I gather that they weren't/aren't a corvette-specific tech. The CE light has been on all weekend, but I assumed that it was just another issue due to the bad grounds.
Old Dec 27, 2005 | 05:46 PM
LoneStarFRC
I guess it's possible someone disconnected the hoses for some temporary reason and just forgot to hook them back up. Re-connect them and look to be sure that the hose(s) are free from any kinks, etc.
Have you checked for codes? Try resetting and see if this helps with your CE light issue. HTH
Old Dec 27, 2005 | 06:17 PM
sowega's Avatar
sowega
I checked the codes, and I had 0410 H C, which is the AIR system. Thanks for the heads up, guys; this site has been invaluable in diagnosing some of the C5's "character."
Old Dec 27, 2005 | 10:02 PM
LoneStarFRC
Old Dec 27, 2005 | 10:27 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Clear the codes and monitor for the return of the CEL. Post what you find.
BC
Old Dec 27, 2005 | 10:34 PM
sowega's Avatar
sowega
I reconnected the hoses and cleared the 0410 code (AIR system). I started the car and let it run for a few minutes, and the CEL didn't come back on. I don't have any other current error codes, but I am concerned that I got "NO COMM." for the RTD, HVAC, and SCM systems.
I know that I have a grounding problem, could it be the culprit in the NO COMMs?
Old Dec 28, 2005 | 12:13 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
No COMMS issues can be caused by a number of issues. What specific symptoms lead you to believe that you have a chassis ground issue?
What year car do you have?
I am a firm believer that grounds should be inspected and cleaned prior to replacing parts and modules. Just as guilty as grounds is dirty and loose battery cables and weak 12 VDC batteries.
Weak batteries and poor battery connections are common causes for U series codes and Loss of COMMS. Check the battery and battery cable connections. The battery cable bolts should be torqued to 11 ft/lbs.
Let me know how you make out.
BC
Old Dec 28, 2005 | 12:43 AM
sowega's Avatar
sowega
BC
It's a 97 A4 coupe. The car has several inconsistent electrical gremlins, all of which, at least according to various threads I've found on this site, can be attributed to iffy grounds. Specifically, the instrument panel lights sometimes don't work, the guages will sometimes go dead, the headlights periodically refuse to go up or down, and the turnsignals sometimes don't work or blink at odd frequencies
Old Dec 29, 2005 | 05:57 PM
LoneStarFRC
If you've ever had water on the BCM due to backed up HVAC drain(s), you may experience a lot of gremlins. In looking at your symptoms, it seems as though most if not all, are related to the BCM. Ever had any flooding or water on the floorboard issues? (Especially on the passenger side)
Old Dec 29, 2005 | 06:09 PM
sowega's Avatar
sowega
I haven't yet checked the HVAC drains, but they're on the list. I'm finding out that whoever owned this car before my dad didn't take great care of it. The good news is that, slowly but surely, all these little issues are being fixed.
Old Dec 29, 2005 | 06:43 PM
Nithros's Avatar
Nithros
St. Jude Partner since 89
St. Jude Donor '09
Does anyone have a photo of exactly where these drains are on the firewall?
Old Dec 30, 2005 | 07:37 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP! Passengere side fire wall, look directly aft of the rear od the cylinder head.
If you look from the top, you can just see it. The flashlight beam is highlighting it.
It will be in a small recessed area and there will be a large wiring harness running over top of it. If you dont have headers, attack it from the bottom. If you have headers, good luck. It best reached from the top.
Here is what it looks like:
Bill
Old Dec 30, 2005 | 07:39 AM
Nithros's Avatar
Nithros
St. Jude Donor '09
Thanks Bill!
To Underhood Questions
