The dreaded PING!
Old Dec 28, 2005 | 02:22 AM
allmee's Avatar
allmee
Default The dreaded PING!
My 01 C5 pings a little when I accelerate hard, sometimes. I've been using injection cleaner evrey 3000 miles. I had Chevy do an injection service and it seemed to get a little worse. The car has 30,000 miles. I bought it with 10,000 on it. I just ordered a fuel filter and am hoping this may do the trick. I am running a Blackwing and flowmasters. I also have the fog light housings cut open. I am thinking the car is getting too much air or not enough fuel. I have'nt touched the wires or plugs yet. What do ya think?
Old Dec 28, 2005 | 02:31 AM
Shane_S's Avatar
Shane_S
Where are you getting your gas and what octane?
Have your car dyno'd and get an air/fuel reading.
New plugs/wires might be a good idea as the factory plugs are junk.
Shane
Old Dec 28, 2005 | 09:08 AM
byte_me's Avatar
byte_me
It still has pretty low miles to have this issue...I would suspect your fuel choice rather then too much air into the engine...I had a similar (aka running like crap) issue with my 97 buying Citgo fuel 93 Octaine. I switched to Chevron with Techron and the engine has never run so smooth. it took about 1 and a half tanks to get it really smooth...but the first half a tank stopped all the pinging issues.
Old Dec 28, 2005 | 09:13 AM
rws.1's Avatar
rws.1
Is it throwing any codes?
It might not be predetonation....
C5's are prone to an H pipe rattle that is often mistaken for engine ping (knock)
If you are not throwing any codes... change your H pipe for an aftermarket X pipe.
Old Dec 28, 2005 | 11:13 AM
allmee's Avatar
allmee
I am using Shell 91 oct. , 91 is the highest here in Vegas. Maybe I'll try Chevron. The noise is definately a knock and I am getting no codes. What type of plugs should I use when I get to changing them?
Thanks!
Old Dec 28, 2005 | 11:38 AM
byte_me's Avatar
byte_me
Thanks!
A lot of us here run NGK TR55's...I use these with MSD wires. NGK also makes an irridium (spelling) that has received lots of praise...but are 3 or 4 time more expensive!
Old Dec 28, 2005 | 01:15 PM
corvette Mark's Avatar
corvette Mark
Try putting the factory air box w/paper filter back on the car and see if the ping gets better or stays the same. I had this trouble with my wife's 01 after I installed an open lid air box cover with k&n filter. After I re-installed the factory stuff the ping was much less of an issue. This is a simple experiment that will cost you nothing but a few minutes of your time. If this does nothing then your next step may be to seek the advice of a custom tuner. I think some of our cars do this because of the "one size fits all" generic factory tune. And we all know that each car is in fact different and have different tuning requirements.
Old Dec 28, 2005 | 01:26 PM
michael wyborny's Avatar
michael wyborny
Shane
I've actually heard that the stock wires are top notch.... anyone else want to chime in on this?
Yes, I agree, what octane you running?
Old Dec 28, 2005 | 01:47 PM
99Red&White's Avatar
99Red&White
I agree, stick with the delco wires and plugs. They cant be beat!
Old Dec 28, 2005 | 04:42 PM
vetteguy02's Avatar
vetteguy02
I would also suggest trying the factor air box again. The mfa sensing elements should be cleaned with isopropyl alcohol or electronic cleaner to remove any oil contamination from the Black Wing filter. Just spray cleaner on the sensing elements and let air-dry. Avoid toching the elements.
Old Dec 28, 2005 | 11:20 PM
allmee's Avatar
allmee
Thanks for all the info! I just filled up with Chevron super and will see if this makes a difference. If not, I will try the stock air box, although I have a K&N for that also and the hole in cover has been cut larger. If I get to that point I will clean the MAS as described!!
Grazie!!
Old Dec 29, 2005 | 01:04 AM
mathia's Avatar
mathia
Look through the throttle and see if you have oil in the intake. You maybe sucking oil into the intake through the PCV and the oil is getting burned up, leaving carbon deposits in the the heads. The carbon deposits become hot spots and can cause preignition. Follow the decarb procedure in the the C5 tech tips to clean it.
Old Dec 29, 2005 | 04:25 AM
SLPRC5's Avatar
SLPRC5
Chevron gas is the best gas to run in the C5, everyone uses it. I have the Delco Iridium plus and the Delco wires. Iridium plugs are what is recommended for the C5s. They are preset at.040 and are highly recommended not to reset them to the .060 that was standard for the C5 plugs. You can also try a couple of cans of Techron to your fuel. This has helped others. Someone also mentioned cleaning the MAF screen because of oil from the Blackwing filter, that to may help.
Good luck..
Rsty
Old Dec 29, 2005 | 04:31 AM
SLPRC5's Avatar
SLPRC5
Decarb with Sea Foam...pour into a vacuum port with the engine running..it will cause a lot of smoke (carbon burning off)...after emptying can in the engine port shut down engine and let sit for ten minutes to cause fogging in the engine.. then take out and drive it like you stole it until all smoke has cleared. Just follow directions on can.
Good luck..
Rsty
Old Dec 29, 2005 | 04:47 PM
Alex D's Avatar
Alex D
I sometimes have the ping too. Mostly when the gas is old and I haven't driven the car much. the more you drive the car the less ping I get. And keep fresh gas in there. STABIL also helps in my car.
Old Dec 29, 2005 | 08:25 PM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
I have a stock '04 A4 coupe. It never "pinged" until I put the Blackwing on. Put the factory airbox back on and the ping stopped. Re-install the Blackwing, ping is back again.
I finally got tired of all the nonsense I was being told and had the timing set back a few degrees. Now, there are no more ping issues and the vette STILL runs like a raped ape with no SOTP difference.
It's just a simple fact that SOME of these cars just will not run on 91 octane gas if you mess with the A/F ratio even a LITTLE bit, like the Blackwing obviously does.
And my "knock sensor" must have been broke from the factory, as when mine started pinging, it continued pinging....especially when I accelerated faster, going up hill. It was rather apparant to me at least, that the onboard computer was unable to make the necessary adjustments in A/F ratio and ignition timing to compensate for the difference the Blackwing made.
"Rattling H-pipe" indeed! What won't they think of next?
Old Dec 29, 2005 | 09:01 PM
BELVIN20's Avatar
BELVIN20
Have 2000 C-5, Blackwing, Corsas, Xpipe, LS1 Edit, AC Delco Iridium Plugs. Never had any Ping before or after mods, always run BP(Amoco Gold Since New), have 25K miles now. Fuel filter will not fix the problem. I suspect Poor Quality Fuel, or Possible the fuel you are using is a winter blend which could make a Ping Problem Possilble.
To The dreaded PING!
Old Dec 30, 2005 | 01:03 PM
corvette Mark
Grazie!!
You are on the right track with the chevron gas but your problem may not go away completely if you re-install the factory box cover with a larger hole cut in the front and a k&n filter. You see the point is that you may still be getting to much air (for the factory tune) or even turbulence in the air bridge from the LARGER hole cut in the airbox cover. This turbulence could be confusing the maf and not allowing the pcm to tune out the ping. You might try using some heavy tape to make the hole closer to the original factory size and then get a PAPER filter. Believe me when I say that I like go-fast parts as much as the next guy and I know it is a hard pill to swallow when someone suggests that you remove them from your car because they may be causing a problem but it is very inexpensive troubleshooting and if this is not the majority of your problem you can put it back on and get a custom tune to get rid of the ping. Many people on this forum run your set-up with no problems but we all know that all cars do not respond the same to mods.
Old Dec 30, 2005 | 03:29 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Try some Torco fuel accelerator, 1 qt per tank.
Old Dec 30, 2005 | 03:40 PM
DeeGee's Avatar
DeeGee
Thanks!
You can get Techron additive at most of the auto shops. Its about $7 a bottle. Checker on Rainbow certainly stock it. It may be worth adding a bottle to see if that helps.
