Leaking gas tank
Old Dec 28, 2005 | 05:06 AM
Dean Prevolos's Avatar
Dean Prevolos
Default Leaking gas tank
I have a 99 Corvette. The passenger side gas tank is leaking fuel. I have run the gas down so I could disconnect the hoses to the sending unit. First, has anyone had this problem on thier 99 and what did you find the trouble to be; the tank or the sending unit gasket? Second, if it is the sending unit gasket ( my gas gauge works), can that be taken out of the tank(like other cars) or is it part of the gas tank as a unit? Third, if I have to replace the tank what is the best way to remove from the car? Any response is welcome, Dean.
