Royal Purple
Old Dec 28, 2005 | 11:23 AM
allmee's Avatar
allmee
Default Royal Purple
What's the scoop with Royal Purple oil? Is it as good as they say or shouod I stay with M1. All I want is to know my motor is well protected and lubricated!
Old Dec 28, 2005 | 11:40 AM
NorCal69's Avatar
NorCal69
5th Gear
Default oil
royal urple is THE SH--
Old Dec 28, 2005 | 12:42 PM
David426's Avatar
David426
Stick with the Mobil 1 and save $$$$. Unless you are racing the car every day and have thousands of dollars into a very hopped up motor, its a waste. It might make you feel better inside but you are just fooling yourself.
Old Dec 28, 2005 | 01:02 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Royal purple is very good oil. Probably one of the best oils that you can get. On the other hand, Mobil 1 synthetic is also a very good synthetic oil. I dont believe the benifits of running royal purple "ENGINE OIL" over mobil 1 "ENGINE OIL" on an everyday LSX engine will be seen or are worth the extra money.
On the other hand,,,,running Royal purple in the differential and transmission is another story! That is where you should use royal purple!
BC
Old Dec 28, 2005 | 01:13 PM
rws.1's Avatar
rws.1
RP are best known for their industrial oils.... gear oils.
I'd stick with Mobil 1
Old Dec 28, 2005 | 02:10 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I run the purple stuff in my FI car, transmission and differential and like the stuff
Old Dec 28, 2005 | 04:29 PM
Lancer033's Avatar
Lancer033
I run RP in the Trans and Diff and M1 in the engine. M1, RP, Redling and AMSOIL are all top quality products. I doubt you will notice any difference between them. The only reason I run the RP is that it is the only Synthetic ATF and gear oil I could find locally.
Old Dec 28, 2005 | 11:21 PM
allmee's Avatar
allmee
Thanks guys, I am going back to M1, which I feel more confident with anyway!!
Old Dec 29, 2005 | 12:58 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Though this isn't an automotive engine oil comparison, it may still interest you. AMSOIL has started including Royal Purple in their comparative oil testing. They just released this comprehensive report on motorcycle oils last month that includes both Royal Purple and Mobil's motorcycles oils. You can draw your own conclusions as to how this relates to the performance of their automotive engine oils.
AMSOIL Motorcycle Oil "White Paper" (1 MB pdf file)
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Dec 29, 2005 | 01:42 AM
allmee's Avatar
allmee
After reading that, RP is looking better than M1. Thanks for the info!!
Old Dec 29, 2005 | 07:31 PM
C66 Racing's Avatar
C66 Racing
You're welcome for the info, but not really sure how you see RP better than M1 in this comparison.
- RP sheared low out of grade in both 40 and 50 weights, M1 stayed in grade in both.
- RP was ranked 9 of 11 (40 weight) and 7 of 15 (50 weight) in High Temp High Shear, compared to M1s 5 of 11 and 2 of 15 respectively.
- RP was ranked 11 of 11 (40 weight) and 15 of 15 (50 weight) in the 4-ball wear test, compared to M1s 1 of 11 (tie) and 7 of 15 (tie) respectively.
- The RP did pass the 40 weight gear wear test whereas the M1 failed stage 13 of 13 with 320mm of wear, but both passed the 50 weight gear wear test.
- RP was ranked 10 of 11 (40 weight) and 15 of 15 (50 weight) in the volatility test, compared to M1s 1 of 11 and 4 of 15 respectively.
- RP failed both the 40 and 50 weight rust tests, whereas M1 passed both
Overall, the test ranked M1 3rd and RP 7th.
Old Dec 30, 2005 | 02:07 AM
allmee's Avatar
allmee
I did'nt look closely enough at the brands and thought AMSOIL was The company that made RP. Thanks for the reply. M1 it is!
Old Dec 30, 2005 | 06:48 AM
Patman's Avatar
Patman
Royal Purple's 5w30, 10w30 and 10w40 all tend to shear down quite quickly, but their Racing 41 is an excellent choice for the LS1. It doesn't thin down as easily and oil analysis results have proven it's completely safe for normal street use, even up to 7 or 8k.
Old Dec 30, 2005 | 07:57 AM
TOOGECKO's Avatar
TOOGECKO
How is their Tranny fluid, specifically Synchromax and Max ATF?
Old Dec 30, 2005 | 08:38 AM
LRD VDR's Avatar
LRD VDR
Shahram
Old Jan 17, 2006 | 03:03 AM
greg_nate's Avatar
greg_nate
M1 seems to do pretty well when stacked up against all the others. Pretty impressive.
Old Jan 17, 2006 | 08:14 AM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I use M1 in the engine,Amsoil in my trans(auto) and Red line in the differential.
To Royal Purple
