How much weight does chroming wheels add?
Old Dec 29, 2005 | 12:37 AM
TheRooster's Avatar
TheRooster
Default How much weight does chroming wheels add?
I wouldn't think chroming the wheels would add a lot of weight but had heard differing opinions. Any ideas how much weight triple plating adds to a wheel?
Old Dec 29, 2005 | 06:30 AM
wrustywrench's Avatar
wrustywrench
to much to notice.....
Old Dec 29, 2005 | 07:40 AM
W.A.M.'s Avatar
W.A.M.
I bought chrome plated 2000 thin spokes which are GM wheels not after market. I think after market wheels are heavier.
The fronts weigh 19 pounds each.
The rears weigh 21.5 pounds each.
I don't know what polished or painted thin spokes weigh.
The chrome thin spokes weighed the same as my 1998 factory wagon wheels.
I don't think the weight difference is anything to worry about.
I saved a lot of weight by going to non run flat tires. Saved about 7 pounds on each rear tire and about 5 pounds on each front tire.
Old Dec 29, 2005 | 07:42 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
less than 1.5 lbs a tire.
Old Dec 29, 2005 | 07:59 AM
Rhode Warrior's Avatar
Rhode Warrior
I think it's a lot less than that. Chrome plating is only microns thick.
Old Dec 29, 2005 | 09:13 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
When chrome plating is applied it's generally "about" .001 thick. Now having said that copper, nickle, then chrome used to be the standard but again the coats are also very thin.
If you calculated the surface area of the wheel to be plated and knew the weight of 1 cubic inch of chrome plate, the weight impact could be easily calculated.
Bob
Old Dec 29, 2005 | 10:08 AM
Evil-Twin's Avatar
Evil-Twin
Microns?????
Do you even know what a micron is???
Chrome plating is in the .001 to .0015 range
a micron is in the .000039 range...
lots and lots of microns to register at .0015
Like I said, it is less than 1.5 pounds a wheel.... less than meaning no more than.... also meaning not significant....considering one gallon of gas weights 6 pounds.
Old Dec 29, 2005 | 11:25 AM
mkleisch's Avatar
mkleisch
I was told 6 grams per square foot for a .0006" thick coating by my guy.
Old Jan 2, 2006 | 08:37 PM
Bob Chapman's Avatar
Bob Chapman
68.9 grams for 4 wheels triple chrome plated - now go find something important to worry about.
Old Jan 2, 2006 | 09:32 PM
Dirty Howie's Avatar
Dirty Howie
Would that be 1.5 for the WHEEL also......
Some of us are unretired folks don't have the time to keep our polished CCW's in prestine condition.
Plus I heard that unsprung chrome weight is the worst.........
DH (currently giving up heavy chromed wheels for lighter polished only)
Old Jan 2, 2006 | 10:20 PM
Rhode Warrior
Microns?????
Maybe you should switch to decaf.
Old Jan 3, 2006 | 01:28 AM
edensknight's Avatar
edensknight
You guys crack me up! In regards to Chroming an entire Aluminum wheel, as ET, in general, mentioned above, chroming adds around a pound or so, and, therefore, is not very much.
Old Jan 3, 2006 | 01:57 AM
DPG's Avatar
DPG
St. Jude Donor '06
you can save the weight of chrome by losing a few lbs yourself
Old Jan 3, 2006 | 11:59 AM
mrgil's Avatar
mrgil
Burnout
Old Jan 3, 2006 | 01:08 PM
racerx175's Avatar
racerx175
Quick question as regards to this, I was told that weight at the wheels is worse the weight elsewhere . Im not sure why , if its even true . Maybe makes the axles work a little more, like I said I have no idea but was told this a quick way to get a little more et , was to get lighter wheels . Thanks for any input..
Old Jan 3, 2006 | 04:05 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Wheel weight is ROTATIONAL AND UNSPRUNG. It is not like 1lb wheel weight=1lb of sprung weight, more like 1lb wheel=4lbs of sprung weight.
Old Jan 3, 2006 | 04:23 PM
DPG's Avatar
DPG
St. Jude Donor '06
You wouldnt want chrome for the track. As for the street, does it really matter. Its more of a show effect and thats why most people run 2 diff rims and tire setups for track and street. If you go drag racing once or twice a yr, i dont think that you are the type that obses ovr et times and what not.
To How much weight does chroming wheels add?
