Three LS7 crate engines!!
Old Dec 30, 2005 | 12:23 PM
KJSDPC's Avatar
KJSDPC
Default Three LS7 crate engines!!
We just recieved three LS7 crate engines in today. They are first come first serve, so shoot me a pm, email, or give me a call! $13,895.00 + freight takes one home, and we can ship today!!
Old Dec 30, 2005 | 01:55 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Tempting!
Old Dec 30, 2005 | 03:35 PM
lost's Avatar
lost
Got the PCM to go with them, cause without one they are a very expensive garage ornament.
Old Dec 30, 2005 | 04:02 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
You can replace the 58x crank reluctor wheel with an 24x LS1/LS6 wheel which is the major stumbing block with the LS1/LS6 PCM.
See here->
http://www.ls1tech.com/forums/showthread.php?t=421576
feeder82's Avatar
feeder82
check out this months issue of HotRod mag they dyno'd one of these beasts with a mild cam and got 600hp
Old Dec 30, 2005 | 05:27 PM
edensknight's Avatar
edensknight
This will be a great engine mod in any C5 to say the least!
Old Dec 30, 2005 | 10:35 PM
Shane_S's Avatar
Shane_S
little expensive for 450rwhp. BUT, this is a completely STOCK motor. no huge thumping cam to cause drivability issues or anything. talk about a sleeper
Shane
Old Dec 30, 2005 | 11:02 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Shane
yes.........but, with ETP C5R heads, Katech 12:1 pistons, BIG cam, bigger injectors and 1 7/8" headers......600 rwhp and 7000+ RPM
(be still my heart )
Old Dec 30, 2005 | 11:54 PM
Mike94ZLT1's Avatar
Mike94ZLT1
Only three?! I have 7
Old Dec 30, 2005 | 11:58 PM
PA_BLUE_C6's Avatar
PA_BLUE_C6
St. Jude Donor '05-'10-'12, '15
WOW!!!
Old Dec 31, 2005 | 12:02 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Six crates and one out of the Z06.
Why did you pull the one out of the Z06??
Someone Blow it pushing nitrous??
Old Dec 31, 2005 | 06:18 AM
JETZ's Avatar
JETZ
Caravaggio got one seven weeks ago!
Old Dec 31, 2005 | 06:36 AM
Shane_S's Avatar
Shane_S
If you're going to do all that then why bother with a crate engine? Just buy the bare block from somewhere and build a C5R engine and not have to worry about a dry sump system and PCM issues.
Old Dec 31, 2005 | 06:37 AM
Shane_S's Avatar
Shane_S
Probably bent valves. My brother-in-law works for Young Chevrolet and he says a few have come back with the same problem. One of them only had 200 miles on it. Bad about valve float.
Shane
Old Dec 31, 2005 | 09:28 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Has anyone done a cost comparison between a built up 427 for a C5 and the LS7 CE? Keep in mind the LS7 is a complete motor with clutch, flywheel, manifolds, injectors, etc.
Old Dec 31, 2005 | 10:11 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
LS7 wins in a direct comparo to the C5R setup. C5R bare block is just north of $6000. Then again the C5R block and the LS7 block are as different as diamond and cubic zirconia.
Old Dec 31, 2005 | 10:15 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Too many unknowns (variables), at this point in time, to make a wise decision. Of course in a few months all of this will change - as pricing and parts availability becomes known.
Bent valve - I would think they'd pull a head(s) and or drop the pan. I wouldn't think they'd pull the motor.
Dropped valve I guess would be a different story.
Either way...OUCH!!
To Three LS7 crate engines!!
Old Dec 31, 2005 | 08:08 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
You can't come close to building a 427 for the price of the crate motor with the pieces in it.
Old Dec 31, 2005 | 11:10 PM
lost's Avatar
lost
What have you been smoking? $6400 for the C5R shortblock,CNC ported LS6 heads,[$1195 from Patriot] and Jet-hots long tubes[tpis] for $600, and the cam of your choice $250-$400, and you you have $5000 left over for tires .wheels,rockers and whatever.The new LS7 is not the end all of all engines, and with the # of problems they are having with valve springs etc.The C5R might well be the better choice.you get the crate LS7 and you have to disassemble it to change the reluctor, not to mention the dry sump system that is not included in crate engine or other little goodies that include no doubt the unavailability of main bolts, as once you remove the crank the old bolts cant be reused...Did anyone bother to read the entire link to ls1tech above?
Old Jan 1, 2006 | 01:19 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
What has JOHN been smoking???
The C5R block..........BARE block is $6250.
We're not talking a shortblock. Shortblocks have rotating assemblies within - crank, bearings, rods, pistons, pins, rings, timing gear (usually), cam etc.
Personally I would not choke it with a set of LS6 heads when far better flowing heads are available.
Yes, some of us have read associated threads on LS1Tech.
