Do you think this is worth it ?
Old Dec 30, 2005 | 11:58 PM
MikeeVet's Avatar
MikeeVet
Default Do you think this is worth it ?
Stage 111 performance Packerages by West Coast corvette gain of 65 HP includes Wcc Hurricane Air Intake ,Wcc Power Duct, 1000CFM Air Senor ,Coolant By-Pass Kit 178 Thermostat Choice of Muffer (Corsa Touring ),X-Pipe, B&B TRI -Flow Stainless Steel Headers ,MSD 8.5 PerformancePlug wires,Diablo sport Predator 99 c5 3,399 $ .. How are the Tri - Flow headers any body out there have them anybody got this pefromance packerage from WWC FEED BACK PLEASE ..
Old Dec 31, 2005 | 12:13 AM
Goody's Avatar
Goody
For $3400 I think you can do much better than that, but that is just my opinion. Long tube headers are where the power and torque is at, those shorties that cost $1K only net about 15hp. (think LG streets, Kooks, Dynomax).
Get one of the more popular cold air kits as the results are pretty much the same for each. (vararam, K&N FIPK, Blackwing, Honker etc).
Unless you are adding cubic inches to the engine you don't need a 1000CFM MAF sensor. The stock sensor flows enough air to support much higher gains than a measely 65hp.
Plug wires don't add power to a stock engine, at least not enough to warrant the cost of them (dollar/hp).
Old Dec 31, 2005 | 12:15 AM
MikeeVet's Avatar
MikeeVet
thank you
Old Dec 31, 2005 | 12:19 AM
mdhmi's Avatar
mdhmi
Most of that is junk you don't need.
Mark
Old Dec 31, 2005 | 12:23 AM
Dave1's Avatar
Dave1
St. Jude Donor '09
Mark
... ....Mark what would you do with $3400 and a stock C5?.....
...Can you do gears with a stall and intake and catback for that?.....
Old Dec 31, 2005 | 12:36 AM
unstressed's Avatar
unstressed
Doesn't sound like your comfortable doing too much wrenching so you will have to pay for some installs.
If it's a 6 speed, I'd do a cold air intake 1st (~$400), then 4.10's (~15-1800 installed), cat back for some sound (~500 used, and easy to install), then if you still have $$$ left over, headers and then a tune.
If it's an auto, I'd go for a cold air intake first (~$400), then gears and a mild converter (~2500-3K installed). Then a cat back for the sound effect. You will need a tune for the gears and converter.
Shortie headers will get you little for seat of the pants increase, spend the money elsewhere.
Old Dec 31, 2005 | 12:44 AM
TheRooster's Avatar
TheRooster
They are trying to sell you a load of junk and not do any labor to install any of it.
With $3400 get:
Intake ~$400
Long tubes ~$1400
Tune (HPtuners or LS1 edit, not a Predator) ~$350
Catback ~$550
and the labor will soak up the rest of the $
That would net you about 55 HP.
A cam and underdrive pulley would net you much higher gains for about $1800 more.
Old Dec 31, 2005 | 02:21 AM
EHS's Avatar
EHS
Mark
Old Dec 31, 2005 | 02:31 AM
Shane_S's Avatar
Shane_S
Are they talking about flywheel or rear wheel. They're probably talking flywheel because i dont see that combo adding 65rwhp.
For that kind of money you can get yourself a set of LG headers, Either the Pro Street series like i have (which arent shorties) or the Pro LT's for ~$1300-$1500 and a G5X2 plus springs, pushrods, retainers and whatnot for $1300. If you can work a deal on install and tuning you might be able to squeeze all that installed/tuned for just under $4000 and you'll make over 100 more rwhp over a stock C5.
Shane
Old Dec 31, 2005 | 02:51 AM
mdhmi's Avatar
mdhmi
$3,400 budget on an A4 car. I'd probably do a larger stall and 3:42's or 3:73's. Long tube headers and a cam are also good bang for the buck mods. Changing the catback at that power level is mainly for sound, not power.
Mark
Old Dec 31, 2005 | 05:15 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Packages are crap, you can do better by following the forums advise.
Old Dec 31, 2005 | 05:35 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Mark
100% Coolant bypass kit.. New MAF..
What a joke...
Old Dec 31, 2005 | 06:43 PM
Var's Avatar
Var
Definitely go with Lg Longtubes and a dynotune. You'll see 30 + horses to the wheels. Save the rest for when you want to get deep into the engine with mods, like a cam or maybe spend it on a clutch or nitrous.
Old Dec 31, 2005 | 07:12 PM
dpd's Avatar
dpd
forget shorties-going with shorties,you mays well throw your money in
the toilet.go longtubes[kooks,dynamaxx,lgm's,etc]
forget the coolant by-pass for 2 reasons,if you gain 1hp i would be amazed,2nd-here in the northeast with the weather we are having now,when the throttle is frozen open as your driving,you will be wishing you didn't bypass it[keeps the throttle from freezing].
free up the air coming in[CAI,vara,etc.],free up the air going out[longtubes,x-pipe,exhaust,hi-flow cats,stay with 3" all the way back if possible],add some gear,if it's a A4.loosen up the converter a tad,cam maybe,etc.,just my .02
Old Dec 31, 2005 | 08:00 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
I think even a representative from WCC (and there are some on this forum) would have trouble recommending that package...and keeping a straight face. As already stated by others, most of the stuff included in that "package" is unnecessary junk. 65hp - no way. You'd be lucky to see 20rwhp, and none of that would come as a result of the coolant bypass, MAF, or plug wires.
I agree with most of the suggestions here, though I think the 3" exhaust would be wasteful overkill on a stock cube non-FI motor. It might even hurt your torque numbers.
Old Jan 1, 2006 | 05:34 PM
edensknight's Avatar
edensknight
Shane
Old Jan 1, 2006 | 11:59 PM
fdxpilot's Avatar
fdxpilot
Since you are in NYC, I would contact Vette Doctors and ask them what they recommend for your $3400. They are in Amityville, out in southern Long Island, and should be able to take care of you.
To Do you think this is worth it ?
Old Jan 2, 2006 | 12:38 AM
shurite44's Avatar
shurite44
Mark
Go with a vararam, long tube headers, and a tune. You will be way ahead of that package with just these two mods.
Old Jan 2, 2006 | 12:51 AM
COLORADO FRC's Avatar
COLORADO FRC
Maybe they'll add a bottle of wax to the revised 2006 kit and call it 66 hp!
Get an intake, long tubes and a good tune!
Old Jan 2, 2006 | 12:21 PM
WardVette's Avatar
WardVette
The B&B headers aren't bad, esp. if you are in California. Only problem is they are too expensive for what they do. I spent $200 on mine used and I was able to install them myself. I probably gained 10-15 hp, lost a little weight, and my car sounds a little better. Great gains for $200 but I'd be sick if I spent over $1K on them.
I have similar mods on my car (the ones that actually help) and I run about .3 and 3 mph faster in the quarter than stock 6 speeds. So, I'd assume that package will add about 30 hp. I spent about $1K on my performance mods. Buy some longtubes for $1200 and you'll see the same gains.
