Turnsignal bulb replacement
Old Jan 1, 2006 | 12:43 PM
LW100's Avatar
LW100
2nd Gear
Default Turnsignal bulb replacement
Sounds like a silly question, however, I'm having trouble accessing the front left T/S bulb, 00 Vette. Appreciate any guidance. Thanks.
Old Jan 1, 2006 | 08:51 PM
lanceg1041's Avatar
lanceg1041
there is an access panel underneath by the turn signals. Jack it up and you can remove the panel to replace the bulb. You'll have to push the cooling duct aside. Should take you ten minutes.
Old Jan 1, 2006 | 09:46 PM
IFLUBYU's Avatar
IFLUBYU
Wierd, I just did this like 30 minutes ago on my 2000. Like the man said jack it up. take off the access panel underneath (and the corner spoiler in the process) You do not need to completely remove the brake duct, just pull the front back from the fascia and push aside. You can access both bulbs from here. the manual talks about removing the bracket and assembly, this is not required unless you are charging by the hour and need to pad your man hours :P
7mm wrench, and/or nut-driver (on a cordless works nice!) and a flash light are all you need.
Old Jan 2, 2006 | 07:09 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
pop up the headlights remove the bezel..reach down inside
Old Jan 2, 2006 | 08:27 AM
Fast98's Avatar
Fast98
Move brake duct out of way reach in and change bulb 30 seconds
Old Jan 2, 2006 | 09:37 AM
FRC Rob's Avatar
FRC Rob
Yup...just 3 screws to remove the headlight bezel. Also unscrew the rubber hood bumper as well, unless you've got little girly hands...my big fat mitts had a hard time squeezing past it. 5- 10 minute job.
Old Jan 2, 2006 | 11:33 AM
DeeGee's Avatar
DeeGee
You got all 3 options there.
I have Z06 screens so the one that works for me is:
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It unscrews counter clockwise but it has a plastic clip which you need to squeeze to release it. Change the bulb. Reseat the bulb holder and turn until it clicks back in place. Put the plastic housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
10 minute job.
Old Jan 2, 2006 | 12:06 PM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
I pop off the head light bezel, then take off the hood stop bumper. (makes getting in there with large arms/hands easier.)
then just reach down, twist and pull.
you gotta be sure the bulb is fully seated though, or it will pop out on the light.
Old Jan 2, 2006 | 04:48 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
All of the above are great tips..........
Old Jan 2, 2006 | 06:59 PM
LW100's Avatar
LW100
2nd Gear
Thank you all for your guidance, it worked!
Old Jan 2, 2006 | 09:26 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
My car finially made it to the body shop on saturday. I waited almost 5 months to get a opening in this shop. They have to pull the nose off the car to back tape, so I told them to replace the DRL and binker bulbs while they were in there.
To Turnsignal bulb replacement
