HELP!! Clutch problems...
Old Jan 1, 2006 | 02:18 PM
CUlookin's Avatar
CUlookin
Default HELP!! Clutch problems...
One of my buddies was in for the holidays so I took him out for a spirited ride yesterday afternoon. Well 3 minutes into the drive I shifted hard into 4th (around 6000rpm) and the clutch slipped a little... I slowed down and went to shift into 5th just to cruise and the clutch basically stuck to the floor (it will come up 2 inches). I basically limped it home with my tail between my legs... It's really hard to get it into gear but the clutch still fully engages (no slipping with the pedal 2 inches up) and disengages when it is pushed to the floor. The car has 7,500 miles on it and is an '04. I have a hurst shifter on it and that is the only drivetrain mod I have installed. Any ideas how to fix this or is my baby going to the dreaded dealer ... Thanks in advance!
Old Jan 1, 2006 | 02:51 PM
6Speeder's Avatar
6Speeder
Simple things first. Fluid level OK?
Old Jan 1, 2006 | 03:00 PM
rgtkst's Avatar
rgtkst
spring?? slave/ master cylinder leaking?? 04 with 7500 miles can you say WARRANTY??
Old Jan 1, 2006 | 03:31 PM
edensknight's Avatar
edensknight
There are TSB's regarding the sticky and intermittant C5 clutch pedal. Therefore, since you are still under warranty (you are very fortunate), get your C5 self to a competent dealership, and, get this issue resolved. And, you will soon be good to go. Good luck.
Old Jan 1, 2006 | 04:24 PM
DRR's Avatar
DRR
When they put in the new clutch be sure to have a remote bleeder installed. You can buy one from LAPD.
Old Jan 1, 2006 | 04:40 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Get the baby to the stealership for the warranty work and pay the extra to install a new Z07 clutch.
Old Jan 1, 2006 | 05:10 PM
CUlookin's Avatar
CUlookin
Thanks guys, I was fed up with it and decided to put my foot behind the pedal and pull up... With just the slightest touch... POP, came up. The fluids were ok so I think it might be a bushing or something with the pedal mechanism...
At least I can drive it to the dealer... I'm going to have my tech check it out anyway, thanks for the responses!
Old Jan 2, 2006 | 06:03 AM
rgtkst's Avatar
rgtkst
DONT FORGET BRING IT TO A DLR TO GET CHECKED
To HELP!! Clutch problems...
