2003 Fuel Filter Replacement
Old Jan 1, 2006 | 05:03 PM
homervet's Avatar
homervet
Default 2003 Fuel Filter Replacement
Help I have a 2003 convertible that I purchased a replacement fuel filter for. I can't locate it on the car..All the info I've been able to locate says it is located in front of the drivers side wheel. Mine is a six speed so it easy to see around the transmission..still unable to locate. Any help would be appreciated
Old Jan 1, 2006 | 05:17 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
The fuel filter is located on the inside of the driver's side frame rail, just forward of the fuel tanks. So it should be just behind (and below) where the driver's seat is.
However, sometime during the 03 model year, the fuel filter was moved from the frame rail to inside the fuel tank. If you can't find yours on the frame rail, it is in the tank and part of the fuel pump assembly - and obviously a major PITA to change out.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jan 1, 2006 | 08:20 PM
dpd's Avatar
dpd
look on the option sticker on the glovebox door.if you see FFS,the filter is in the left tank attached to the top of the fuel pump/sender assembly.only way to get to it is drop the tank
Old Jan 1, 2006 | 11:24 PM
homervet's Avatar
homervet
Thanks for the info..I do have FFS option..GM does it again..Make a simple job a nightmare..I won't be changing that filter for a while
Old Jan 2, 2006 | 03:17 AM
BlownZR's Avatar
BlownZR
The FSS systems fuel filter is good for 100K miles.
To 2003 Fuel Filter Replacement
